Introduction: How to Make a 3D-ish Ball Thingy in 3 Easy Steps!
this instructable is going to show you how to make a ball in autodesk sketchbook! With even different colored edges if you want!
Step 1: The Tool and Start
Use the airbrush tool to create a big circle of the color of your choice. The color might be a little bit lighter if you want you can change it or keep it the same.
Step 2: Making It a Ball
To make it a ball you will need to select the fill tool and then make the color black or white and then you fill the background and bye then the background won’t be fading in with the other color. (I recommend that the tolerance is between one hundred and two hundred)
Step 3: Final Step
(This step is optional) Now it is time for the final step! Tap the white circle under the layer that your on and then select a color that you like! Now add a little white thing with the airbrush at the top left of your ball. Now your done and if you want you can experiment with this and try different things! I hope you enjoyed making this project.
