Introduction: How to Make a BSOD and Scare Your Friends
This Tutorial Will Take You Step By Step Into Create A Fake BSOD (Blue Screen Of Death) And Scare Your Friends or Family!
Step 1: Opening Software We Want to Make It In.
Now To Make This You'll Need A Program called "Notepad" Which Is A Built In Program For Windows.For Any Version Of Windows, Even 1.0.
You Can Find It In The Start Menu
Or Windows Key+R And Type Notepad
Step 2: Code
It's A Very Long Code
Don't Type IT By Looking At The Image It Will Take 1 hour
So Here's The Code:
@echo off
echo ^ ^ ^ BSOD^ > bsod.hta echo. >> bsod.hta echo ^> bsod.hta echo applicationname="BSOD" >> bsod.hta echo version="1.0" >> bsod.hta echo maximizebutton="no" >> bsod.hta echo minimizebutton="no" >> bsod.hta echo sysmenu="no" >> bsod.hta echo Caption="no" >> bsod.hta echo windowstate="maximize"/^> >> bsod.hta echo. >> bsod.hta echo ^^ >> bsod.hta echo ^ >> bsod.hta echo ^
A problem has been detected and windows has been shutdown to prevent damage to your computer.^
>> bsod.hta echo. >> bsod.hta echo ^DRIVER_IRQL_NOT_LES_OR_EQ UAL^
>> bsod.htaecho. >> bsod.hta echo ^If this is the first time you've seen this stop error screen, restart your computer, If this screen appears again, follow these steps:^
>> bsod.hta echo. >> bsod.hta echo ^Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.^
>> bsod.hta echo. >> bsod.hta echo ^If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.^
>> bsod.hta echo. >> bsod.hta echo ^Technical information:^
>> bsod.hta echo. >> bsod.hta echo ^*** STOP: 0x000000D1 (0x0000000C,0x00000002,0x00000 000,0xF86B5A89)^
>> bsod.htaecho. >> bsod.hta echo. >> bsod.hta echo ^*** gv3.sys - Address F86B5A89 base at F86B5000, DateStamp 3dd9919eb^
>> bsod.hta echo. >> bsod.hta echo ^Beginning dump of physical memory^
>> bsod.hta echo ^Physical memory dump complete.^
>> bsod.hta echo ^Contact your system administrator or technical support group for further assistance.^
>> bsod.hta echo. >> bsod.hta echo. >> bsod.hta echo ^ >> bsod.hta echo ^^ >> bsod.hta start "" /wait "bsod.hta" del /s /f /q "bsod.hta" > nulStep 3: File Format
So yes Just Click File then Save As Then Save it as BSOD.bat It must be a .bat file in order to work. Don't Save It As A .txt or .vbs file because then it's not gonna work.
And Also Save as type should be All Files or it's gonna come as a .txt file (text file).
And Now Click Save.
Step 4: Run It!
Don't Worry, It's Not Real, And It's Harmless It Will not damage your PC at all. It's Also Simple By The Way
Just Press Alt+f4 to close!
