Introduction: How to Make a Baby Pacifier for Neodymium Magnets?
Magnetic born-again doll pacifiers are made with strong neodymium magnets. A tiny magnet of about 12 mm x 2mm pellet shape can stand up to 3 pounds of pressure. So if you put an opposite magnet inside the reborn doll's mouth or inside your doll's head, behind the mouth, the pacifiers will hold up well.
Beloved reborn master and lovers of these fantastic infant dolls! I want to show you exactly how to make magnetic pacifiers. It's my experience, it constantly functioned. I such as that a magnet ends up being level with plastic, there is no projection. And moreover, it stays better, it does not obtain loose. To better improve the magnet - as opposed to normal adhesive, you can utilize material glue, so it never loosens again.And afterward, let's reach function. We do not require a big set of devices that is in each master's residence and just typical tools that all of us have. Whatever you need will probably remain in your residence. You will require to buy just 12 mm x 2mm neodymium magnets, pacifiers, and also adhesive.
Tool & Materials:
- scissors
- glue
- Scalpel
- tweezers
- Wooden stick
- A piece of wool
- drill
- Neodymium magnet
Step 1: Step 1:Cut Off the Pacifier
Cut off the latex part on the nipple, pay attention to safety, and do not hurt your hands
Step 2: Step 2:Punch
Then, take the drill and drill the plastic inside. Remember that the neodymium magnet measures 12mm x 2mm
Step 3: Step 3:Clean the Inside of the Pacifier
Inside, there are still plastic and gum remains. Cut gently into the excess and remove it.
Step 4: Step 4:Stuffed Wool
See this piece, impeccable, without any extra details. We take a piece of cotton or cloth, as you wish. Pour the glue in the center of the workpiece and place the paste inside. With a wooden stick, we squeeze it and pour the glue again. At this stage, we don’t postpone our future pacifier for a long time, take the pupa, try the polarity of the magnet, save it, and stick it. To fix it, a wooden stick is needed and then, for the magnet, the magnet will be magnetized and will ruin everything.
Step 5: Step 5:Stick Neodymium Magnet
Step 6: Last Step:Adhesive Assembly
Although there are many different pacifiers on the market (some are connected to plush toys, some are "specially" used for breastfeeding, etc.), we found that reverse psychology is the best way to keep pacifiers in your baby A bite. In other words, every time your baby tries to take the pacifier out of his mouth, he will pull it away a little until they suck. This method teaches your baby to put the pacifier in his mouth. DIY baby pacifier solves this problem very well
Magnethub is a professional Neodymium Magnets Manufacturer, we are happy to provide you with suggestions for DIY neodymium magnets
