Introduction: How to Make a Babydoll Nightie Dress From 2 Men's Shirts
About: I am a DIY maven when it comes to making and re-imagining trends and making them affordable! Staying on trend is an exercise in creativity...I value crafting pieces myself and not buying into brand cache. My b…
Sorry guys!  This will show all your ladies how to steal your striped shirts to make a sweet babydoll-style A-line dress, which can also be worn as a nightie.  Or as a regular dress!
The original instructions I found in the book "Kakkoii Couture Remake," and I adapted the how-to to U.S.-sized shirts and changed the construction so that you only have to use up 2 shirts instead of 3 - which I thought was too much of a waste.
Happy DIY'ing...and please check out my blog www.chic-steals.com for TONS more men's shirt refashions and DIY tutorials!
xoxox
Carly
Step 1: You Will Need:
*2 men's button-down shirts in coordinating colors (I used size 16 - I think that's an L, but I recommend using an XL if you are a S/M Misses'...or an XXL if you are L/XL Misses.')
*thread matching topstitching thread in shirts
*23" of 3/4" wide flat elastic (white)
*110" elastic cord (white)...we'll be gathering fabric so only about 36" will be used eventually, but you need a longer length to do the gathering properly.
*sewing machine
*needle for wovens
*fabric scissors
*seam ripper
*iron (optional)
*1 safety pin
Step 2: PREP YOUR PARTS: Cutting
Iron your shirts if they are rumpled..  (Mine were- and I didn't bother ironing them - and my finished dress is kind of rumply too!)
Cut Shirt #1 according to the diagram: the sleeves off the shirt and straight across the top just under the second button.  This will serve as the body for your dress.
Step 3: Make the Dress Body (Construct the Front Insert)
To make the front insert, first cut the sleeves as shown - you'll be cutting the cuffs off both and discarding. Pin the sleeves together on the long side closest to the sleeve opening placket. Sew together with a 3/8" seam allowance, open up the piece you just sewed, and lay flat.
Step 4: Make the Dress Body (Adding the Insert)
Turn the insert piece upside-down and pin both sides of it to the underside of the opened shirt front we cut in Step 1), matching bottom hemline. (Underlap about 3/8 - 1/2" on button placket.)
Sew to shirt front vertically along button plackets. (not pictured)
Step 5: Make the Dress Body by Finishing the Front Pleat
Close top button. On underside, create pleats in front insert, and pin to underside of front.
Sew a line straight across the top of the insert, through all layers, catching all the pleats. (This will result in a visible line of stitching through the front of your dress.) Then sew button placket closed vertically, above the line you just sewed, going through all layers.
Step 6: Make the Bottom Ruffle (Cut Your Pieces)
Button up Shirt #2 and lay flat. Mark 7.5" up from the bottom, and 7.5" above that. Cut shirt straight across, through both layers, at both marks.
Step 7: Make the Bottom Ruffle (Constructing the First 2 Pieces)
Using the bottom of the shirt as a guide, hem the upper strip in a similar fashion (note the center front and center back of the shirt is lower than both sides). I just traced the shape of the bottom hem, added 3/8", turned under, and stitched a 1/4" hemline. (I know, technically the top strip needs to be 7 and 7/8" tall, not 7.5"...but we won't tell anyone.;-) It's easier to explain this way.)
Step 8: Making More of the Bottom Ruffle (Cutting the Final Piece)
Cut the remaining piece of Shirt #2 according to the photo below: cut the sleeves off, and cut the yoke off the back (we'll use the yoke later on).
As to the sleeves, mark 7.5" down from the top of each sleeve, and 7.5" down below that. Cut sleeves straight across at those marks. (We won't be using the cuff pieces.)
Step 9: Making More of the Bottom Ruffle (Construction of Final Piece)
Pin each sleeve piece together at sides to make one long continuous piece. (In this order: Sleeve cap + bottom piece + sleeve cap + bottom piece. If you're totally anal about this piece matching the hemmed pieces from Step 7), cut one of the bottom pieces in half widthwise - and pin each half to the outside edges of this joined piece. I.e., bottom piece half + sleeve cap + bottom piece + sleeve cap + bottom piece half. But I'm lazy and so didn't bother - and I think in the finished dress you really can't tell.)
Sew sleeve pieces together. Hem edge that has the rounded part of the sleeve caps in a similar fashion to the piece you hemmed in the previous step, cutting off the extra to create a similar hemline.
Step 10: Making the Bottom Ruffle (Connecting All 3 Pieces & Gathering)
Connect all 3 ruffle pieces together by sewing them at their sides with a 3/8" seam allowance. (Connect all so you've made a continuous piece.)
Make a double knot in the end of your elastic cord. Place it on the wrong side, along the top of the ruffle piece you just sewed (about 3/8" from the edge). Using a loose zigzag stitch on your sewing machine, zigzag over the elastic cord all the way around the ruffle piece. Do not stitch through the cord - it must remain free and moveable under your stitches. Backstitch a couple times at the beginning and end of your stitching to strengthen it.
Pull on the un-knotted end of the cord, gathering the fabric underneath it. Gather the ruffle piece until it is basically the same circumference as the bottom of your dress.
Step 11: Finishing the Bottom Ruffle
 Pin the gathered ruffle to the bottom of the dress, right sides together. The bottom of the dress is already a curvy hem - pin the straight side of your ruffle around these curves. This will create a beautiful wavy hem when finished. Double-knot elastic cording again once you have verified the pinned length of the ruffle - then cut off the extra.
Stitch ruffle to bottom of dress, stitching below the elastic cording.
Step 12: Gather the Dress Top
1. Fold under top of dress about 1"+. Stitch straight across bottom of folded edge to create a casing.
2. Attach safety pin to one end of your flat elastic. Thread through the casing and out the other side.
3. Match end of elastic to edge of dress; stitch down the edge to secure.
4. Hold the elastic firmly and gather the front fabric - the finished width of your dress front needs to be 11.5".
5. Once at the correct width, stitch down the other end of the elastic, and trim so nothing is visible from the front.
Repeat for the back of the dress - the finished length for the back needs to be 10.5."
Step 13: Make the Shoulder Bows
Cut the back yoke off Shirt #1 (as well as from Shirt #2...which we did in an earlier step). (The yoke is usually double-sided; if yours isn't, you have to scavenge fabric from somewhere else on your shirt. I think the ties look best when the stripe pattern is going up and down the length of the tie, not from side to side, so I chose an area where I can get a piece of fabric 17.5" long with the stripes going up and down.)
1. Sketch out the following shape onto both yoke pieces: a tall trapezoid, with the top side 1.25" wide, the bottom 2.5" wide, and the entire piece 17.5" tall.
2. Cut shapes out, separate the fronts from the backs, and remove any labels with a seam ripper.
3. Fold each piece over, right sides together, and sew along longest edge, pivot, and along shortest edge.
4. Turn piece right side out, and topstitch along unstitched edge to flatten it. (You can also iron it at this point to flatten it out further.)
5. Pin each piece under the top of the dress, at both front and back, about 1/2" down from top hem, on either side. I positioned the pieces matching the dress body at the front, and the pieces matching the ruffle at the back.
Stitch across strap through all layers using a zigzag stitch for strength.
25. Tie bows tightly to prevent slippage.
Step 14: You're Done!
Though I've followed the directions from the book exactly for making the shoulder-bows, I find them too thin - the bows aren't full and pretty, but instead look skimpy - like dragonflies perched on my shoulders. I would recommend if you wanted fuller bows - to either use fabric from other parts of the shirt and double the width of the cut parts...or cut the pieces as I wrote above and instead of folding them in half, just fold under the raw edges about 1/4" and topstitch to keep in place (eliminating Step 22)- thus leaving you with single-layer fabric bows instead of double-layer.
You now have a super-cute dress perfect for lounging about, a sweet babydoll nightie appropriate for the boudoir - or even, under a blazer and over jeans or leggings, a chic piece to add into any day ensemble. Or you can wear it out as is during warmer months - rocking it with some lace-up sandals, a little metallic clutch, and a rhinestone clip in your hair.
Happy DIY'ing!
xoxo
Carly
