Introduction: How to Make a Ball-Kicking Based on MBot
This time mBot will shoot by kicking instead of pushing the ball. How amazing it is!
Step 1: Install Two Brass Studs on MBot
Part List:
2 x Brass Stud
Step 2: Install the Plate L1 on the Brass Studs
Part List:
1 x Plate l1
2 x Screw
Step 3: Install RJ25 Adapter on Plate L1, Then Connect the Wire to Port 4
Part List:
1 x RJ25 Adapter
2 x Screw
2 x Nut
Step 4: Install the Servo on the Acrylic Bracket
Part List:
1 x 9g Micro Servo Pack
1 x Acrylic Bracket
2 x Screw
2 x Nut
Step 5: Install the Above Servo Model on the Bracket U1
Part List:
1 x Bracket U1
2 x Screw
2 x Nut
Step 6: Install the Parts Together
Part List:
1 x Acrylic Bracket
1 x Nut
1 x Flange Bearing
1 x Screw
Step 7: Install the 9g Servo Into the Above Acrylic Bracket (step 12)
Part List:
1 x 9g Servo
2 x Screw
2 x Nut
Step 8: Install the Above Models Together, As Follow:
Part List:
2 x Acrylic Bracket
2 x Screw
2 x Nut
Step 9: Install the Acrylic Bracket and the Beam0824 Together, As Follow:
Part List:
1 x Beam0824
1 x Acrylic Bracket
2 x Screw
Step 10: Install the Above Beam0824 Model on the Servo Arm
Part List:
1 x Acrylic Spacer
1 x Screw
Step 11: Install the Whole Servo Arm on MBot
Part List:
2 x Screw
Step 12: Install the Ball-kicking Device on MBot, Then We Finished Building a Ball-kicking MBot.
Part List:
1 x MEDS15 Servo Motor Bracket
2 x Screw
2 x Nut
