How to Make a Diy Cage
Intro: How to Make a Diy Cage
Today I am making a cage which is approx 12 inches from all sides ,it's compact size for birds and rabbit as well
if you don't understand something please watch the video and vote for this instructable
STEP 1: Materials
16 pieces of 12 " x 1.25 " wood
Wire net
1.5 inches nails
2 inches nails
Wood glue
thin wood for covering net
wooden board
STEP 2:
Make 2 squares out of 4 wood pieces
STEP 3:
Cover it with net wire with thin wooden pieces
STEP 4:
Insert the two pieces inside the square by cutting them down on 3 inches apart leaving a center for door
cover the sides with net
STEP 5:
Place wood piece on edges of the squares and hammer down the 2'' nails from the upper side make a cube same with door part
STEP 6:
Cover all the sides with wire
STEP 7:
The bottom dimension is 14'' by 14'' cut out the board and place it over the bottom and secure it with nails
STEP 8:
Take a dimension it's 10.5'' cut out two pieces and place them inside the hole take other dimension between those two pieces and cut out 4'' of two pieces joint them as a rectangle size for the door and cover with net
STEP 9:
Place the door knob on the door and put door hinges on the sides
our cage is complete for birds and small pets
