How to Make a Bow Out of Dowels
Intro: How to Make a Bow Out of Dowels
This Instructable will show you how to make a bow and arrows out of dowels. For those who dont know much about bows, when you make a bow you ideally want to cut a length of wood, shape it, and let it age for a year. If you make a "green" bow, it looses its power after a few days. This Instructable will show you how to make a bow that is quick and easy to make, very inexpensive, requires no tools or experience, and can be made by almost anybody. It also can be experimented on with different sizes, shapes, number, etc. of the dowels.
---Note: the arrows shown are improvised....... i will make an instructable for arrows later....
STEP 1: Materials
You will need:
--5/16" x 36" dowels (x3)
--3/16" x 36" dowels that are as straight as possible (x as many as you want they are arrows) these would just be until you could make some decent arrows that would be light enough to work
--scotch or duct tape; i used scotch because it is easier to work with
--shoe laces (x9) i use shoe laces because they are just the right length, and they have that little thingy on the end that makes them easier to thread
--golf tees (x2)
--a large cork
--a ruler/measuring tape
--scissors or a knife
--sharpie
--golf tees (x2)
--a large cork
--sharpie
STEP 2: Starting the Bow
First, take two of the 5/16" x 36" dowels and mark their centers. Then take the third one and mark it in quarters.
Okay now line up the dowels so that the one marked with quarters is in the center and the halves of the first two dowels line up with the outermost quarters of the third one... see the picture this is a confusing step.
After you line up the dowels, tape them in place so you can tie them together more easily. they should be in a pyramid/triangle shape after they are taped, NOT flat.
STEP 3: Tie the Bow Together
Now you need to tie the bow together. Its kind of hard to explain other than you need to make sure it is very tight and make sure your knots are secure. You could also use glue to hold the knots in place if you want. Its easier to explain with the pictures.
STEP 4: Add the Arrow Rest
This step is completely optional, but i dont like either options of wearing gloves or getting splinters in my hand, so i made an arrow rest. Basically, the cork needs to have the wide side up, and be on the opposite side of whatever hand you hold the bow with. Lace it on.
STEP 5: Bend the Bow
Now you need to bend the bow into an actual bow shape. This can be done by propping it in between two things that are stable, and can be left overnight, and arent going anywhere. I used two shelves. It shouldnt be bent very far, just enough so the bowstring wont be right up next to the bow--it can be adjusted after the bowstring is in place.
STEP 6: Add the Bowstring
This is another step that is kind of hard to explain. Looking at the pictures will be much easier than trying to follow the directions.
------Now you need to attach the bowstring. To do this I used golf tees, but you could use almost anything that is wider at one end then the other. The washer has no real function, i just put it there for good luck ;) just tie it on the same way you tied everything else.
Now to make the actual string itself. To do this, take two laces and tie one end of them to each golf tee. Then, tie three half hitches or any slip knot that will not slide when you don't want it to around one string with the end of the other. Repeat this for both ends. This will allow you to adjust the bowstring without retying it.
STEP 7: Conclusion
Now the bow is done!!! I have found that this particular version is not particularly pwoerful, and It probably couldn't be used for any heavy duty uses, but you never know. Try experimenting on the design and post your comments!
4 Comments
jlai11 11 years ago
Experience: constant traditional bow shooter
rimar2000 14 years ago
jacob13 13 years ago
i hope that helped somewhat...
bgat 14 years ago
