Introduction: How to Make a Box
This is a tutorial on how to make a box that can stick together without needing tape or glue.
6 Pieces of square paper (each different colored sheet will add more color to your box)
Step 1: Initial Creases
take a piece of paper and fold it in half (top to bottom), then fold the top and bottom to meet the middle line
Step 2: Fold Corners
fold two opposite corners to meet at the first line
TIP: remember which corners you folded, each paper should be done the exact same way
Step 3: Fold Top Flap
fold the top flap down to meet at the middle line
Step 4: Corner Fold
take the corner of the top flap that hasn't been folded yet and fold it to meet at the bottom folded line
Step 5: Fold Bottom Flap
Fold the bottom and meet at the middle line
Step 6: Corner Fold
Similarly to step 4, fold the bottom flap to meet at the top of your paper. In order to make the pattern in the image, tuck in the fold beneath the top flap
Step 7: Side Creases
Now flip the paper over. fold the sides in. Then unfold
TIP: when both sides are folded correctly, it should make a square shape
Step 8: Repeat
Repeat the last 7 steps until you have 6 pieces that are all identical
Step 9: Combining 2 Pieces
take 2 pieces and stick one of the sides into the flap of the other
Step 10: Combining 3 Pieces Pt1
repeat step 9 with a third piece
Step 11: Combining 3 Pieces Pt2
connect the side that is not yet connected
TIP: for the next few steps, I prefer to flip this over
Step 12: Combining 4 Pieces
Similarly to step 10 & 11, it will take 2 insertions to connect the 4th piece. insert carefully
TIP: this may start to fall apart, but don't worry just follow the steps again to get back to where you were
Step 13: Combining 5 Pieces
This step needs 3 insertions.
TIP: I recommend inserting the new piece first, then sticking the edges into the new piece.
Step 14: Combining 6 Pieces
The hardest step needing 4 insertions
TIP: as before insert the new piece into its position before putting the sides in
Step 15: DONE!
Now you have your finished box!
