Introduction: How to Make a Buttonhole Corsage.
In this Instructable we show you how to make a buttonhole corsage using inner tube of a bike and Nespresso coffee capsules. We hope you like our Instructable. Materials we used to make the corsage are cleaned Nespresso capsules, cleaned inner tube of a bike, a circle punch (1.5 cm diameter) a metal brooch, a round metal rivet, 657117 Sizzix Bigz Die - Flower, Petal Power by Eileen Hull, a Bigshot, a flower punch, a glue gun, scissors, cutting pliers, flat nose pliers and round nose pliers
Step 1: Watch the Video
To see how to make this buttonhole corsage in detail, watch this video.
Step 2: Cut Out a Coffee Pod Circle
Cut of the top and the bottom of your coffee pod. Use a circle punch to cut a circle of about 1.5 cm in diameter. Hereafter cut out a paper circle. Fold this paper circle onto 8 pieces and mark.
Step 3: Cut Your Circle
Use the paper circle to cut your coffee pod circle. Leave the middle uncut. Now fold one in two of the cut pieces around the tip of a pencil. Now put this piece to the side.
Step 4: Cut Out Your Flower Base
Use the Bigshot to cut out a flower from a piece of bicycle inner tube. Use this together with the first prepared piece in the next step.
Step 5: Attach the Two Pieces
With a round silver colored rivet, attach the prepared coffee pod piece and the inner tube flower.
Step 6: Prepare Another Coffee Pod
Cut the border of a coffee pod. Use a round nosed plier to turn the coffee pod regularly. When you have turned all around, fold them slowly inward.
Step 7: Prepare the Stem
Use a small flower punch to cut out coffee pod and inner tube flower. Pierce the second prepared coffee pod and add e brooch to it. Now pierce the coffee pod flower and cut the petals a bit.
Step 8: Finish the Corsage
Add the flower and fold the petals around the coffee pod. Hereafter add the inner tube flower. Use a glue gun to attach the top part and your corsage is done. We hope you like our Instructable.
