How to Make a Cardboard Gernade By benlsteawrt in LivingToys & Games8012Introduction: How to Make a Cardboard Gernade By benlsteawrtFollowMore by the author:this is a instructable on how to make a cardboard grenadeSuppliescardboard Scissors Small Rubber band Pen Pin Key ring Toothpick Step 1: Arrange All Your Pieces Step 2: Cut Out Five Pieces in This Shape Step 3: Hot Glue the Pieces Into a Circle Step 4: This Is the Hard Part Bend the Tips in and Hot Glue Them Together Then Flip It Over and Repeat on the Other SideStep 5: Cut a Piece Perpendicular to the Ridges on the Cardboard About a Quarter Inch Wide by However Long Your Grenade Is Step 6: Pull the Top Layer of Cardboard Off Carefully Step 7: Hot Glue the Piece to the Grenade and Repeat Steps 4,5,6 Four More TimesStep 8: Hot Glue a Square of Cardboard to the Top Step 9: Cut Off the Edges Step 10: Cut Lots of Little Squares Out of Cardboard Step 11: And Glue Them to the Grenade Step 12: Cut Three of These Pieces Out of Cardboard One Slightly Smaller Then the Other Two Step 13: Hot Glue the Smaller One to a Piece of Cardboard. That Is the Handle of the Grenade Step 14: Hot Glue the Two Bigger Pieces of Cardboard to the Grenade Like This Step 15: Slide the Handle in and Make a Hole Through All Three PiecesStep 16: Slide a Toothpick Through Step 17: Cut the Ends Off and Seal Them With Hot GlueStep 18: Take the Pin and Key Ring Step 19: Slide the Pin Into the Key Ring Step 20: Poke the Pin Into the Grenade Step 21: Cut the Rubber Band Step 22: Hot Glue the Rubber Band Like This So When You Pull the Pin the Handle Flies Up Step 23: Fill the Bottom of the Grenade With Chopped Up Pieces of Cardboard or Pop-itsStep 24: Cut a Piece of Cardboard That Fits on the Bottom of the Grenade Step 25: Throw the Grenade Against a Wall and Watch Whatever You Put in It Fly Out!
