Introduction: How to Make a Catapult With Littlebits
This is a easy project for kids , can be used in many things , this is a catapult or a throwing arm.
Step 1: The Materials for This Project
The materials are:
- Battery 9v &cable
- Power module
- Servo module
- Button module
- Servo mount & servo hub
- Mechanical arm
- 3-Screws
- Board
- Tape
- Paper cup
*Note: all this things you can get it in littlebits.*
Step 2: Connect the Cable to the Battery of 9V
We proceed to connect the battery of 9V for power the circuit.
Step 3: Connect All the Modules
We proceed to connect the module power to turn on the circuit , then we connect the button module when we pressed lets the signal through to the servo ,when connect the servo gets the signal it turns, rotating the arm and throwing the projectile.
Step 4: Press Servo
Press servo into the servo mount and screw in and then put the screw.
Step 5: Mount the Circuit to the Mounting Board
Once the board is mounted you put the cup in different ways of your choice, be creative!!!
Step 6: The Best Moments
You can use for many things , in this case to play basketball.
