Introduction: How to Make a Charcoal Chimney
Lighting charcoal briquettes without lighter fluid is easy with this homemade Charcoal Chimney. While you can easily buy one of these things for under $15 at your local hardware mega-store this one can be built for practically free.
This is my very first Instructable.
Step 1: Opening the Can
Materials Needed
- 1 #10 tin can (coffee can)
- 1 can opener
- 1 church key
- 2 Wire coat hangers
- 1 drill with a 1/8" drill bit
- 1 pair of diagonal cutters
- 1 pair of needle nose pliers
Step 2: Making the Vent Holes
Using the church key make a series of triangular holes on one side of the can separated by about 2 inches (this side will be referred to as the bottom)
Step 3: Drilling the Holes for the Wire Mesh
Drill two sets of eight holes about 3 inches from the bottom of the can with about 3/4 of an inch separating the 2 holes in each set
Drill 4 holes for handle (see illustration)
Step 4: Making a Wire Mesh
- Open the coat hangers and straighten with the pliers
- Cut the coat hanger into 12 8 inch pieces using the diagonal cutters
- With the pliers form a hook at one end of each of the 12 pieces of wire about 3/4" in diameter
- Thread the straight end of the wire through the can to it's opposite hole making sure to thread the hook end into it's corresponding hole
- Insert the hook into the the hole nearest it and using the pliers, on the inside of the can bend the wire so that it cannot be removed from the can.
- Repeat the inserting process for all the holes, you may have to drill additional holes and place additional wires to make a tighter mesh depending on the size of charcoal you plan to use. (I had to do this.)
Making the Handle
- For the handle drill 2 sets of two holes, one set at the top of the can and another near the mesh. Drill the sets vertically
- take the remainder of the coat hanger and fasten it in the same manner done when creating the mesh
Step 5: The Finished Product
And there you have it one Charcoal Chimney for the price of a few Band-Aids. It's not the prettiest thing but it does work.
You can see it in action on this OpenTutorial tutorial How to Light Charcoal Without Lighter Fluid
Warnings
- Be careful, I cut myself twice while building this be smarter than me, use gloves.
- I make absolutely no claim to the safety of this project, make it and use it at your own risk. There are professionally built Charcoal Chimneys on the market. Please consider buying one if for any reason you feel uncomfortable about making your own.
