Introduction: How to Make a Charm Necklace
Follow our steps.
Step 1: Step 1
List of stuff that you’ll need in this process:
-tong
-charms (including coins and a panthertag)
-jasseron (approx 75 cm)
-bending rings
-measuring tape
-closures
-extension piece
Eventually (perhaps if you make a gift)
-some nice wrapping paper
-plastic bag
Step 2: Step 2 :
Make sure you choose the right measurements, it obviously depends on the circumference of your neck. Then you are going to divide the jasseron into two parts with the tong, one longer than the other. Lay those two parts next to eachother.
Step 3: Step 3
After you've cut the jasseron you lay them next to each other, and fold them evenly so that the charm fits in the middle (you can see how you would lay the charm to do this step).
Step 4: Step 4:
Put a bending ring in the middle of the jasseron and in the bending ring put your big charm and then with a tong close it.
Step 5: Step 5
Put also on the endings above a bending ring (both ending).
Step 6: Step 6
Measure the jasseron and look/divide where you're going to put the coins. Close the coins with a bending ring and tong.
Step 7: Step 7
On one side go the coin necklace and on one side of the big charm necklace put a lengthening piece and close all three with a bending ring and tong. On the other side of the coin necklace and the big charm necklace put a closure and close all three with a bending ring and tong.
Step 8: Step 8
Final result of the necklace!
Step 9: Step 9
Perhaps
If it's a gift you may wrap it in nicely
First ,put the necklace in a plastic bag. Then cut the paper and fold it in the proper size. Then staple the paper and bag together.
Step 10: Step 10
This is how it will look!
