Introduction: How to Make a Clay Volcano
Materials
1.)Cartoon
2.)5 Stack of clay
3.)Softdrink
4.)Stack of Mentos
It is easy to make a clay volcano. There is some fails sometimes. This is because the soda is not cold. This experiment is fun. Make sure you do it correctly.
Step 1:
First, gather these materials: a cartoon, 5 stacks of clay, a soda, and a stack of mentos. You must shake the soda a bit. Make sure you did not shake it too much. This is a safe experiment. The materials are easy to get.
Step 2:
Next, you need to make the clay volcano structure. This is a color you want. But first you put the cartoon at the bottom. Make sure you did not leave any hole at the structure. The soda might explode.
Step 3:
Then you must make the decoration at the side. Like the trees, lava, broken trees, and even more. Add anything you like. Specially the animals that are running away from the lava structure .
Step 4:
For The Final touch, you put in all the mentos. It will start to bubbles and the coke will go explode or go out. then if you want to do it again just put the coke then the mentos. You like to do this. Well do it now. It is pretty easy. So easy !! Make sure you did the right step. Bye!! ^_~
