Introduction: How to Make a Cool Robotic Arm
About: LewanSoul specializes in product development and creation, especially in the field of bionic robots, we provide the majority of users with superior hardware and software products. We have manufactured robots&r…
LeArm is a high performance programmable robotic arm. It can move very flexible and grab in different directions. Full metal body structure makes the robotic arm stable and beautiful!
Now, we make an introduction to its assembly. So you can give it a shot and make your own robotic arm.
Step 1: Assemble the Chassis (1)
Required materials:
A set rotational station*1
Bearing *1
Copper pillar and screws* several
Screw caps *several
Screwdriver *1 pcs
You need to twist the screw to the rotational station as shown in the picture, then put the bearing onto the rotational station. And use copper pillars and screw caps to fix these two planchets.
Step 2: Assemble the Chassis (2)
  • At first, you need to fix the side cover bracket to the wafer with screws and screw cpas.
  • Then take out another wafer and the servo horn, put the bearing onto the rotational station.
  • Join these two things together.
  • Fix these two wafer into rotational station with screws.
Step 3: Assemble the Chassis (3)
  • At first, you need to put the LD-1501MG servo to the wafer and use screws to fix it.
  • Then put the wafer with servo to the rotation station . (picture 3)
  • Join copper pillar and screws together.
Step 4: Fix the Servo With Brackets
  • At first, you need to use screws to join two brackets.
  • Use screw to fix LDX-218 servo to the bracket on rotational station.
  • Use screw to fix brackets with LDX-218 servo.
Step 5: Assemble Base Board for Robotic Hand
Use a base board to fix our robotic arm.
And winding tube can reduce your wiring troubles. It can make your robotic arm more attractive.
Step 6: Actions Display
Step 7: Use Mobile Phone to Control the Movement of Robotic Arm
