Introduction: How to Make a Cork Coaster
Let’s bring a little encouragement to the table with laser engraving cork coasters!
These lightweight, eco-friendly coasters come to life with words that motivate engraved right onto the surface with precision and warmth. Whether it’s “Cheers,” “Breathe,” or “Keep going,” each phrase turns an everyday object into a small reminder of strength.
Ready to turn positive vibes into practical style?
Machine Used
Thunder Bolt 30W
Material Needed
Cork Coaster
Engraving
- Speed:1000mm/s
- Power:10%
- DPI:335
Step 1: Place Your Cork Coaster for Laser Engraving
Cork coaster should be as flat as possible.
Before your work begins
- Verify the lens is clean or there's no problem in the laser.
- Make sure the exhaust fan is working well.
- Ensure the air assist is on.
Step 2: : Open the Custom Coaster File
Import the custom cork coaster design in LightBurn and check if your coaster size is large enough.
Double-check everything, and decide if you want to add or subtract elements according to your preferences.
Step 3: Focus on the Cork Coaster
Without focusing, your outcomes may fall short of expectations. So before starting, make sure you’ve rightly focused.
For focusing, you have two options: Auto Focus, which is simple—just press the AF button on the Thunder Bolt screen. Then you’re ready to have a laser engraving.
Step 4: Frame the Cork Coaster Design and Start Laser Engraving
When you click “Frame”, the red light will display the laser engraving area. This is a safe process, and the frame will align with the cork coaster. Once aligned, simply press “Start” to begin the cork coasterlaser engraving with the Thunder Bolt!
Step 5: Monitor the Laser Engraving Process
To avoid any issues, carefully monitor the laser engraving, especially when unusual conditions like alarms arise.
Considering the laser cutting energy, for safety reasons, we advise against staring directly at the process, even with the laser door closed.
Step 6: Complete the Custom Cork Coaster Laser Task
When the custom pcork coaster laser engraving is completed, it’s time to get it out. Enjoy this unique piece!
Come and Try!
Perfect for home offices, coffee corners, care packages, or thoughtful gifts, laser engraved cork coasters are easy to customize and ship, making them a feel-good favorite for small creative shops and mindful brands alike.
