Introduction: How to Make a Crochet Chain
In this set of instructions, you will be learning how to make a crochet chain. The crochet chain is the starting step in most large scale crochet projects like scarves, blankets, or sweaters. Get comfortable and let's start crocheting!
- Yarn or String
- Crochet Needle or Fingers
- Scissors
Step 1: Tie a Loose Knot Around Your Finger or Crochet Needle.
Step 2: Tie the Loose Knot a Second Time.
(This ensures that the loop will keep its integrity while completing the following steps.)
Step 3: With Your Free Hand, Take the Long Side of the Yarn or String and Cross It Over Top of the Loop on Your Finger or Needle.
Step 4: Grip the Yarn or String That Is Above Your Starting Loop.
- If using a needle: use your index finger to hold it in place.
- If using your fingers: use your thumb to hold it in place.
Step 5: Grab the Bottom Loop With the Index Finger and Thumb of Your Free Hand and Slightly Lift It.
(Don’t be alarmed if the loop’s size increases, this will help.)
- If using your fingers: once you lift the yarn or string, go underneath your bottom loop with your thumb and grip the top loop in between your thumb and index finger. (bottom right photo)
