Introduction: How to Make a Crown
this project is the very first i made with EVA foam . hunting the damn thing here was a challenge , since nearly noone sells it .
so i had to make a crown for my Suh Wang Moh cosplay , last year . being a complete neophyte in working with eva foam , it was a process full of learning and a lot of trial and error .
Step 1: Concept and Planning
first , we need to make the concept vector .it's better if you make it 1:1 in dimensions and think about the overlay of your crown .
next you need to deconstruct your crown , making a printable template for the eva foam .
Step 2: The Foam
since i used 2mm foam , i had to cut the outlines with scissors . it took the better half of a day , trying to go exactly with the shapes .when you have all your shapes cut , you need to use something to make them less absorbant . since most "exotic" art supplies are lacking around here , i had to go with the wood glue technique .
coat your parts in wood glue before painting them , either with acrylic paint or directly with spray paint . i used golden spray paint , copper accrylic paint for highlights and a little bit of brown acrylic to make the shadows .
after that , use varnish spray to seal everything .
Step 3: Gluing Everything Together
make a base with a large headband , making sure it can support the parts . either buy a large black one or use felt to cover one (like me )
start gluing your parts and embellishing with pearls , acrylic gems etc .
