Introduction: How to Make a Cute Fox Decoration
This cute fox can be a present to someone it could be a cute decoration too.
hope you enjoy doing it
The materials need to make this cute decorations is
· Cardboard
· Cutting device
· Paint
· Pencil
· Glue (Hot glue or Liquid glue)
Step 1: Sketch
To make a 3d fox you will have to first sketch out a fox on cardboard with a pencil
Step 2: Cut
Then cut out the fox out with a cutting device that you have at home
Step 3: Trace
Then trace the fox on another cardboard with a pencil
Step 4: Cut Again
Then cut the fox number 2 as well
Step 5: Strips
Cut cardboard into 4 long strips
each strip has to be
width is 3cm length is 23
Step 6: Strips Plan
Plan out where you want the strips to be
Tip
It is better if the strip is two millimeters away from the edge.
Step 7:
Then put liquid glue or hot glue on the outer side of the fox.
Step 8: Stick
Then use the strip that you cut out before, and glue it on its side, where you put the glue.
Step 9:
Let the glue dry, if you used hot glue then it will take around 15 to 30 minutes if you used liquid glue then it would take 3 hours max.
Step 10: Stick Again
Stick the other template of the fox that has no drawing in it on top of the strip you glued.
Step 11: Same Thing Again
Do the same thing for the other half but put the glue all around where you want it to be and so that it will match with the first half, after that glue them together and wait, if you used hot glue then it will take around 15 to 30 minutes if you used liquid glue then it would take 3 hours max.
Step 12:
After its dried and you are happy with your shape get creative and colour it in how ever you want.
Step 13: You Are Done!!!!!
Now you have a cute decoration :)
