Introduction: How to Make a DIY Alarm Clock With LCD Keypad Shield
Hi everyone! In this instructable, I'm gonna show you how to make an Alarm Clock using Arduino Board. I've used Arduino UNO, LCD keypad Shield, 5V Buzzer and Jumper Wires to build this clock. You can see the time on the display and able to set time and alarm. The buzzer rings the alarm when the current time equals to preset alarm time. You can also able to turn off the alarm and use this as a normal clock. Not only them but also you can set the alarm ringing time. When the alarm rings, you'll certainly wake up because it sure makes me. All right, let's move to the part list which we need to build this.
*Arduino UNO or MEGA - Arduino UNO or Arduino MEGA*
*Arduino Keypad Shield - Keypad Shield*
*Buzzer - Buzzer*
*Jumper wires Female to Female*
Step 1: Item List
- Arduino UNO
- 16x2 Character LCD Keypad Shield
- 5V Buzzer
- Jumper Wire Kit
Step 2: Wiring
For The Wiring please follow the Wiring Diagram
- Place the Keypad shield on Arduino
- connect A1 - Buzzer Signal
- connect GND - buzzer GND
That's All the wiring you need to do
Step 3: Code
The code is pretty self-explanatory
The Code is through this link: Code
Default time for alarm is 8:30AM(change line 139 to the time of ringing and 35 and 36 1 min after your time )
press RST button on keypad if you want ringing to stop
UP = Minutes + 1 (Current Time)
DOWN = hours + 1 (Current Time)
Step 4: Testing
!@Your Set-up now should look like this.
After uploading the code,the LCD will show the wrong time. It means you need to set the time. The default time for when turned on is 8:30AM .You can use UP(Minutes + 1), and DOWN(hours +1)to set the time in 24hr format. If you Reset it or it loses power you will need to set it again so BE CAREFUL!!!
Step 5: DONE!!!
Please Like and share this instructable! If you have any questions, please post them below!!
