Introduction: How to Make a DIY Mason Jar Lamp
SUBJECT: DIY Crafts
EDITED BY: Lynette Delgado, Emma Bjerklie
INTRODUCTION: A lamp made from household materials. These instructions are to guide you through making a DIY Mason Jar Lamp. It’s important to follow each individual step correctly and safely to achieve the finished product.
WARNING: Do not leave DIY Mason Jar Lamp unmonitored for more than two hours to reduce the risk of possible fire.
MATERIALS:
· 6-foot indoor extension cord
· A non-grounded lamp holder adapter
· Hot glue gun with glue sticks
· Standard size mason jar with lid and lid-tightener
· Standard light bulb
· Scissor
· Loofah
Step 1:
The mason jar should have the jar lid and jar lid-tightener attached to the mason jar.
Step 2:
Use a scissor to puncture a hole on the top of the mason jar lid. The hole needs to be the size of the lamp holder adaptor.
Step 3:
Use the scissors to widen the hole by sticking the top in and opening the scissors to get the desired width.
Step 4:
Remove the lid-tightener and lid from the mason jar. Put the adapter through the opening of the hole, prong side facing out of the jar lid.
Step 5:
Twist the lightbulb into the adapter until tightened.
Step 6:
Plug the extension cord to the prong end of the adapter. At this point, the lid and lid-tightener should be loosely fitted over the adapter.
Step 7:
Put the light bulb end into the jar and tighten the lid and lid-tightener back on the jar.
Step 8:
Cut the string around the loofah with the scissors.
Step 9:
Unravel the loofah completely.
Step 10:
Hot glue the loofah to your liking on top of the mason jar lid only. Be sure not to hot glue the mason jar lid and mason jar lid-tightener together or you will not be able to change the light bulb.
Step 11:
Ensure the extension plug on top of the mason jar is unnoticeable.
Step 12:
Cut the excess of the loofah off with a scissor and hot glue the end under the material.
Step 13:
Wait five minutes to let the glue dry before plugging in. If it’s going to be for more than two hours, make sure it is being monitored.
