How to Make a Denim Shirt Dress
Intro: How to Make a Denim Shirt Dress
Gather all materials such as:
- Measuring tape
- White elastic band
- Denim shirt
- 50 strips of 32 x 5-inch tulle
- Fabric scissors
- Ballpoint pins
- White chalk
- Needle
- White and pink thread
- One yard pink cloth
STEP 1: Measuring
Materials you will need for this step:
- Measuring tape
- Elastic band
- Denim shirt
- chalk
- Safety pins
- Ballpoint pins
- 1 yd cloth
- Fabric scissors
1st step: Measure your waist
2nd step: Measure the elastic band to the same size as your waist, trim if needed.
3rd Step: Apply denim shirt onto the mannequin.
4th step: Measure from the underarm area to the desired length( I chose 9 inches), then mark with white chalk
5th step: Apply the elastic band around the denim shirt along with the white chalk, safety pin w/ pin at the end to keep it together.
6th step: Measure cloth from the size of your waist + 5 inches (will explain why later on) and desired length, cut if needed with fabric scissors. ( My waist is 32 inches and I chose the length to be 22 inches)
STEP 2: Applying the Tulle to the Elastic Band
7th step: Apply tulle under the elastic band, bring it over, cross it over, tie a knot
8th step: Repeat until the elastic band is around the whole elastic band.
Should look like the pictures above
How to tie the knot included in the pictures^^^^^^^
STEP 3: Sewing the Cloth Onto the Elastic Band W/ Tulle
Grab the cloth that SHOULD be measured by now ( your waist + 5 inches and desired length)
9th step: Add cloth along with the elastic band with tulle against a table
10th step: Grab a needle and pink thread, measure a GOOD amount, if short, it's fine, grab more.
11th step: Create a running baste stitch along with the fabric, DO NOT SEW THE EXTRA 5 INCHES!
After that:
Once sewn together, apply back onto the mannequin and secure it with a safety pin and pin.
Warning: You will see the 5 inches not sewn on right now
STEP 4: Applying the Top to the Bottom
Take the denim shirt off the mannequin and apply onto the table, along with tulle skirt
13th Step: Align the white chalk streak with the elastic band and put pins along into band it together.
14th step: Test it out! ( be careful with the pins!!)
15th step: Once all the pins are secured, button up the denim shirt
16th step: Start sewing the same running baste stitch across the band and shirt( Make sure it's even and then sew the extra 5 inches across the other side
17th step: Make sure that the ends of the elastic band are sewed on the shirt and each other
18th step: Once both the top and bottom are secured to each other, try it on!
STEP 5: Enjoy!
PS, I'm just a sophomore in high school, go easy on me.
Warnock-NTHS 4 years ago
