Introduction: How to Make a Duct Tape Phone Case
I really needed a case for my phone when I was at the Beach cause it kept getting sandy and wet. So I built the second one in ten minutes.
But i wanted better so i built the first one.
Step 1: Supplies
Duct tape- I used 2 colors or you can use more if you want
Ruler
Exacto Knife or Scissors
Cutting Board or Something to cut on
Phone or Ipod
and velcro
Ruler
Phone or Ipod
and velcro
Step 2: Step 1
Measure your phone/ipod and double that number then add a few extra inches.
Cut that
Cut that
Step 3: Step 2
Take the 10 in. strip and wrap it around the phone.
then cut out strips to go across the bottom so the phone doesnt fall out.
Then stick 1/3 of it on one side and wrap it around to the other side.
Step 4: Step 3
Cut out another strip like 1 more inch then the origonal strip. wrap that sticky side down on the longer strip u cut.
Then cut more strips that will cover the sticky parts left on the bottom.
Step 5: Step 4
Cut a strip as long as the case and tape it to the back leaving half hanging over. You will need three of these.the second one faces the opposite way and the third faces the opposite of the second and then fold the excess over. You will then attach velcro to the top flap and case.
Step 6: Step 5 (optional)
Cut out two strips add one inch to each side so if the belt is 1 inch wide cut a 3 inch strip. Cut it so that there is a little sticky stuff open and put that on the back of the case.
Step 7: Conclusion
Rate Comment and have fun with duck tape
(hint hint: the splatter paint tape rocks.)
