Introduction: How to Make a Easy Crochet Scarf With Puff Stitch
Stay warm and cozy this winter with this pretty Crochet Scarf. Crochet Scarves are the most fun , easy and quick projects to whip up. With just simple stitches you can make yourself a pretty and cozy crochet scarf. They also make beautiful gifts for your loved ones.
Here’s a very pretty and simple crochet scarf pattern that will keep you warm and cozy during those cooler months. Today am sharing the pattern for this Easy Crochet Scarf with Puff Stitch. The pattern is made by repeating only 1 round untill you reach the size needed. The pattern works up quickly and the Puff Stitch gives the scarf the rich textured look.
You can make them as regular style scarf with free ends or make them little longer and join both the ends to make them into infinity scarf to wrap around your neck twice. Add fringe or tassels to the ends to make them more pretty.
7.5/ 45 Inches - can be customized to any size
Visit https://rajiscrafthobby.blogspot.com/2022/01/how-to-make-easy-crochet-scarf-with.html
8 Ply Cotton Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 42.
This measures 7.5 inches. You can change the size of the scarf by increasing or decreasing these starting chain stitches.
Step 3:
Round 2:-
1 Single Crochet in the second chain from the hook.
1 Single Crochet in each stitch of the remaining stitches.
Chain 1 and turn.
Step 4:
Round 3:-
1 Single Crochet in the First stitch.
Skip 1 Stitch.
1 Puff Stitch in the next stitch.
Skip the next stitch.
Repeat(1 Puff Stitch, Skip 1)
1 Single Crochet in the last stitch.
Chain 1 and turn.
To make a Puff Stitch:-
- First pull up the yarn on the hook to a height of a double crochet.
- Yarn Over, insert hook in the same stitch and pull up a loop. Do not complete the stitch(3 loops on the hook)
- Again, Yarn Over, insert hook in the same stitch and pull up a loop.(5 Loops on the hook).
- Lastly, Yarn Over, insert hook in the same stitch and pull up a loop.(7 loops on the hook).
- To finish the Puff stitch, Yarn Over and Pull through all 7 loops.
- Chain 1.
Step 5:
Round 4:-
1 Single Crochet in the first stitch.
Skip the puff stitch.
1 Puff stitch in next stitch(i.e in between the two Puff stitches)
Repeat(1 Puff Stitch) in between each of the puff stitches.
Chain 1 and turn.
Step 6:
Round 5 Onwards:-
Keep Repeating Round 4 untill the size needed.
