Introduction: How to Make a Easy Sunshine Crochet Square Block
Crochet Square Blocks are a versatile project to make. Crocheted Squares have a tremendous variety of ideas that they can be used for. Right from basic Crochet Coasters to a Complex Clothing Accessory. They can easily be joined or sewed together to make pretty Crochet Bags , Pillows Table Mats and Blankets.
Brighten up your Crochet Projects with this Easy Sunshine Crochet Square Block. This is a very easy pattern and works up real quick.The pattern is started off in a circle worked in rounds and finished off in a Square Shape. Crochet Square Blocks are a very popular choice to make among many crocheters. They are easily customizable to any Size you wish to make.
5 Inches- Customizable to any size
Visit https://rajiscrafthobby.blogspot.com/2024/06/how-to-make-easy-sunshine-crochet.html
8 Ply Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Magic Circle.
Chain 4(the starting Chain 3 will be counted as a Double Crochet and the remaining stitch will be counted as Chain 1 space)
1 Double Crochet
Chain 1
Repeat(1DC,Ch 1) untill you have 12 Double Crochets.
Slip Stitch into the 3rd Chain.
Step 3:
Round 2:-
Slip Stitch into the Chain Space.
Chain 2
2 Double Crochets in the same space.
Repeat (2DC) in each of the chain spaces.
Slip Stitch on top of the first Double Crochet.
24 Stitches.
Step 4:
Round 3:-
Chain 2.
1 Double Crochet
1 Double Crochet(change yarn color while pulling the yarn through the last 2 loops),
1 Front Post Treble Crochet in the stitch from the previous round i.e. Round 1(change back to the first yarn color while pulling the yarn through the last 2 loops)) - this makes 1 increase
Repeat(1DC,(1DC,1FPtrbl(in the previous round))
36 Stitches.
How to make a Front Post Treble Crochet??...here it is.....!!
- Yarn over hook twice, Insert the hook under the stitch i.e from the front of the stitch to the back of the stitch and Pull up a loop(4 loops on hook).
- Yarn over, pull through 2 loops on hook (3 loops remain on hook).
- Yarn over, pull through 2 loops on hook (2 loops remain on hook).
- Yarn over, pull 2 loops on hook (1 treble crochet complete).
Step 5:
Round 4:-
Chain 2.
(2 Double Crochets , Chain 1, 2 Double Crochets in the next stitch) - that's the 1st Corner made.
1 Half Double Crochet each in the next 2 Stitches.
1 Single Crochet each in the next 3 Stitches.
Repeat((2DC,Ch1,2DC in the next St),1HDC*2,1SC*3,1HDC*2)
44 Stitches, 4 Chain 1 spaces.
Step 6:
Round 5:-
Chain 2.
1 Double Crochet in each stitch untill you reach the Corner.
In the Chain 1 Space make - (2 Double Crochets, Chain 2, 2 Double Crochets)- that's the corner made.
Repeat(1DC in each stitch untill corner),(2DC,Ch2,2dc)-in corner stitches)
Slip Stitch on top of the first Double Crochet and weave off.
***If you wish to make a large size square, then keep repeating Round 5 untill the size needed.
