Introduction: How to Make a Factory That Don’t Do Nothing
Hello, I make a supposed factory that don’t produce nothing I make the most of LEGO, and I like it and I that you too.
  1. A little box (preferable a box of 17.1 cm (6.75”) x 9.5 cm (3.75”) x 12 cm (4.75”))
  2. Cold silicone
  3. A brown paper of foamy
  4. A silver paper of foamy
  5. A red paper of foamy
  6. Scissors
  7. A bag of green foamy
  8. Gold paint
  9. Some little paintbrushes
  10. A pizza box
  11. A sealant tape
  12. A ruler
  13. A pencil
  14. A black marker
  15. Some small chopsticks
  16. 1 pieces of a: technic, axle 10
  17. 3 pieces of : technic axle 6
  18. 2 pieces of : plate 2 x 2 round with axle hole
  19. 1 piece of a: tile, round 2 x 2 with bottom x
  20. 1 piece of a: technic, axle pin 3l with friction ridges lengthwise
  21. 5 pieces of: technic, gear 24 tooth (New style with single axle hole)
  22. 7 pieces of: technic, bush 1/2 smooth
  23. 1 piece of a: technic, axle connector (smooth with x hole + orientation)
  24. 1 piece of a: technic, gear 8 tooth type 1
  25. 2 pieces of a: technic, gear 12 tooth double bevel
  26. 1 piece of a: technic, liftarm 1 x 2 thin
  27. 2 pieces of:technic, bush
  28. 6 bricks 1 x 2
  29. 1 brick 1 x 1
  30. 1 brick 2 x 2
  31. 1 plate 2 x 3
  32. 1 plate 2 x 2
  33. 3 plates 1 x 2
  34. 1 technic axle pin with friction ridges lengthwise
  35. 1 seat 2 x 2 x 2
  36. 1 brick 1 x 2 with axle hole
  37. 1 brick 1 x 2 with pin hole
  38. If you have: 1 tile 1 x 2 with Gauges and buttons pattern
  39. If you have: 1 slope 30º 1 x 2 x 2/3 with Gauges Pattern
  40. 1 minifigure
  41. 1 utensil radio with extended handle
(You can use similar pieces for the mechanism)
Step 1: Strengthen the Box 📦
Cut a piece of sealant tape to strengthen inside and outside the box 📦.
Step 2: Make the Holes 🕳️
Next make holes for the mechanism that is inside the box 📦.
IMPORTANT: (The hole that’s above need to be according to the size of the gear that have 24 teeth)
Step 3: Make the Base for the Mechanism ⚙️(below)
Cut a piece of cardboard (of the pizza box) according to the size of your box (5.5 cm x 9.5 cm) and make a hole in the cardboard piece according to the little hole and paste it (with cold silicone) according to the axle 10.
Step 4: Make Mechanism (Gear 1⚙️)
To make the mechanism of the 1st gear ⚙️ you need: (the axle 10, 2 bush, 4 bush 1/2 smooth, 1 liftarm 1 x 2 thin, 1 axle pin 3l with friction ridges lengthwise, 1 gear tooth double bevel, 1 gear 24 tooth (New style with single axle hole)). First you put axle 10 and a liftarm 1 x 2 thin and above you put a axle pin 3l with friction ridges lengthwise and below you put 2 bush 1/2 smooth and 1 bush. Then you put it in the box, and put: 1 bush,1 gear of 12 tooth double bevel, 1 gear of 24 tooth (New style with single axle hole) and we leave a small space and we put a bush 1/2 smooth. We put the axle 10 in the hole of the base and we put an other bush 1/2 smooth to do pressure.
Step 5: Make the Base for the Mechanism ⚙️ (above)
You cut 2 pieces of cardboard (of size of: 5.5 cm x 8 cm) with 2 holes for the other 2 gears ( with 2.5 cm between each one) then paste it (with cold silicone).
Step 6: Make the Mechanism (gear 2 ⚙️)
You make the mechanism of the 2nd gear ⚙️ you need:(1 axle 6, 1 gear 8 type 1,1 bush 1/2 smooth, 1 gear 24 tooth (New style with single axle hole), 2 plate 2 x 2 round with axle hold, 1 tile, round 2 x 2 with bottom x). First in the axle 6 put a gear 8 type 1 you put it in the first hole and put a bush 1/2 smooth the a gear 24 tooth (New style with single axle hole) and put it in the other hole and put the 2 plate 2 x 2 round with axle hole and then the tile, round 2 x 2 with bottom x.
Step 7: Make the Mechanism (Gear 3 and 4 ⚙️)
For the mechanism of the gear ⚙️ 3 and 4 you need: (2 axle 6, 2 bush 1/2 smooth, 2 gear 24 tooth (New style with single axle hole), 1 axle connector (smooth with x hole + orientation). First in the axle 6 put a bush 1/2 smooth and put it in the first hole then put another bush 1/2 smooth to do pressure and put the gear 24 tooth (New style with single axle hole) put it in the other hole and put the axle connector (smooth with x hole + orientation) and the other axle 6 with the gear 24 tooth (New style with single axle hole).
Step 8: Make the Mechanism (gear 5) 1
For the mechanism of the gear ⚙️ 5 (1) you need: (6 bricks 1 x 2, 1 plate 2 x 3, 1 plate 2 x 2, 3 plates 1 x 2, 1 brick 2 x 2, 1 brick 1 x 2 with axle hole, 1 brick 1 x 2 with pin hole, 1 axle pin with friction ridges lengthwise, 1 brick 1 x 1, 1 tile 1 x 2 with Gauges and buttons pattern, 1 slope 30º 1 x 2 x 2/3 with Gauges Pattern). First you put 2 bricks 1 x 2, 2 times then connected together put it the plate 2 x 3 above each one in each side, then in the center of the plate 2 x 3 you put the brick 1 x 2 with axle hole beside you put the plate 2 x 2, then above behind you put a brick 1 x 1, then you put the brick 1 x 2 with pin hole and you put the axle pin with friction ridges lengthwise. Above the plate 2 x 2 in one side you put a brick 2 x 2, and below you put 2 plates 1 x 2 and above you put 2 bricks 1 x 2. Then above the brick 2 x 2 you put the seat 2 x 2 x 2, then above the brick 1 x 1 you put seeing the seat 2 x 2 x 2 a plate 1 x 2, now you put the tile 1 x 2 with Gauges and buttons pattern and the slope 30º 1 x 2 x 2/3 with Gauges pattern.
Step 9: Make the Mechanism (gear 5) 2
To make the mechanism of the gear 5 (2) you need:(1 gear of 24 tooth (New style with single axle hole), 1 chopstick and cold silicone). First broke (no totally detached) the a small piece in the two sides of the chopstick then put the two gears of the mechanism (you need to take out the gear 4) then broke some small piece (they can been of 0.8 cm approximately) and paste it back of the chopstick then that are in the gear then put the gear that you take out. And put the other in the axle pin with friction ridges lengthwise.
Step 10: Decoration 🖼️
You cut this pieces that are in the photo and paste it like the photo, then pint the sides of the box, you can decorate with green foamy to suppose that is a mess.
Step 11: Finish ✅
You finish! I want that you like it. 👍🏼
