Introduction: How to Make a Fan From an Old Pc Power Supply
And this instructables I’ll show you how I made this small fan using a PC power supply. Do note that the power supply is from inside the PC. Without further do let’s get making.
An old pc power supply
Screwdriver
Soldering iron
Hot glue gun
Shrink tubing
A drill or drill press(this is optional)
Step 1: Remove the Pcb
Step 1:This step is pretty straightforward. Just remove all four or five screws. And cut the wires to anything that you wanna leave inside.
Step 2: Drilling, and Gluing
Step 2: Use your drill or drill press to make a hole. To make sure that I got the right size for the connector to fit in the hole. I grabbed a drillbit and poked it in the connector to see if it was the right size. Gluing it is pretty simple, put the connector on one side and plug it in on the other so it’s holding up on the wall. Now get your hot glue gun heated up and apply glue around the connector. Make sure you don’t get any down in the cracks or inside of the connector itself .
Step 3: Soldering
Step 3: I don’t have a wiring diagram. But wiring it is pretty simple connect the red wire from the fan to the red wire on the plug-in. Take the black wire from the plug-in and run it to one of the wires on the switch run the second wire from the switch back to the black wire on the fan. Make sure to add shrink tubing so that the wires don’t touch and short circuit.
Step 4: Final Touches
Step 4: screw the top back on. You can leave the 130 V plug-in for looks. Or you can take it out and add something of your own. Be aware of how many volts you are putting in make sure to not put in more than 12 V on these PC power supplies, if you could fry the fan. Happy making!
