Introduction: How to Make a Fan With Little Bits Accesories Controller by a Slide Dimmer
This is a fan controlller by a slide dimmer, in this case we're using a 9V battery for power , a button for control the display and the speed of the fan . This can use in a room , garage , anywhere.
Step 1: Materials for This Project
The materials are:
9V battery
Power module
Light sensor module
Battery cable
Fan module
Display module
Mounting board
Elastic band
Step 2: Connect the Battery to the Cable
We proceed to connect the battery of 9V for power the circuit.
Step 3: Connect All the Modules
We proceed to connect the module power to turn on the circuit , then we connect the slide dimmer module to change the speed of the fan ,next we connect the display module and put it in count up to increase the speed , and if you put in count down to reduce the speed and finally connect the fan module.
Step 4: Mount the Circuit to the Mounting Board
Once the board is mounted you can put ti on different ways of your choice, be creative!!!
