Introduction: How to Make a Fire
Have you ever wanted to make a big and exciting fire? Well, I am going to tell you. Knowing how to start a fire efficiently, making it last long, and safe is important. With these tips you will be able to make a fire that will wow everyone watching.
Step 1: Collecting the Fire Wood
Now go find some wood, the best place is really any gas station or anywhere it is not illegal. I find this is the best way to clean your grove out.
Step 2: Lighting the Fire
When starting a fire, you want to get some gas and put a little on with nothing lit. Pouring gas on a fire that is lit is not smart, because fire will travel up a stream of gas and that makes for some scary encounters with gas. If it needs something to help it keep going then put some diesel fuel on it. Diesel burns longer, is hotter, and will give you time to put it on and get out of harm’s way.
Step 3: Enjoy Your Fire
Make sure you will let the fire burn out, so you do not have to put water on it. The reason being that all the ash mixed with water makes a rock, so let it burn out. After a few hours, your fire is doing fine and is a good time to let it burn out. If you would like your fire to continue, put some more wood on it.
