Introduction: How to Make a Fire Effect in Photoshop
Do you have any idea regarding fire effect in Photoshop? By using Adobe Photoshop premier pro easily you can add any fire effect to any text or images.
Step 1:
Do you have any idea regarding fire effect in Photoshop? By using Adobe Photoshop premier pro easily you can add any fire effect to any text or images. So guys if you want to add a touch of fire into your text Photoshop is a great space to go. In this article we will tell you the step by step guide on how to make fire effect in Photoshop.
Let me describe you the steps: Open Adobe Photoshop:At first set the background color to black and foreground color to orange.
Step 2:
Create a new documentSet it whatever size as you wish and in the background contents select color and then click ok.
Step 3:
Render cloud:From the filter menu select -> Render -> clouds
Step 4: It’s Time to Save Your Fire
Now the filter will render Gaussian cloud by the help of foreground and background color. Different color will create an interesting effect.
Step 5: Now Create a Document With Text Layer
For an instance, use a normal background which contains the word “FIRE”. IF you have found that you have an existing document, keep an original backup copy.
Step 6: It’s Time to Duplicate the Text
Now drag the original text layer into a new layer. Drag it into the bottom of the layer window
Step 7: Apply Gaussian Blur
Select Filter-> Blur-> Gaussian Blur
Step 8: Smudge Tool
Now Photoshop will give you a warning message that the user will not be able to edit the real text if you processed. Ok the blur so that it looks like this shape.
Now click on the smudge tool which is below the gradient tool. Click on the brush setting at the top of the Window. With this settings you are going to draw the fire image.
Step 9: Create the Flames
Here the short, quick strokes will give you the appropriate result. Suppose you are using a brush then vary th e thickness by pressure. When done duplicate the smudged layer.
Step 10: Now You Need to Apply the Radial Blur
From the filter menu select blur then select radial blur.
Step 11: Then Convert It to Indexed Color
From the image menu you need to select the mode and then select the indexed color. You can choose your favorite color from the color table.
source: https://clippingpathgraphics.com/fire-effect-in-photoshop/
