How to Make a Food Warmer
Intro: How to Make a Food Warmer
Hi, This is my first Instructables I am publishing so if any mistakes please I am sorry for it.
Well, anyway this project I decided to to do because well I wanted to make cheap machine running a day which can let the food be warm inside. I Had some cardboard lying around I decided to use it in some useful way and this is it Food warmer.
STEP 1: Step 1 : Cutting the Flaps
Our first step is cutting out the front flaps till it reaches the bigger flap size of the cardboard box.
STEP 2: Step 2: Aluminum Cover
Cover the whole box with aluminum form inside using glue gun also cover the flaps with aluminum as they will be closed of to inside.
STEP 3: Step 3: Putting the Heating Element
Now take two wooden block and mark the hole for bulb holder and drill the hole for it also make a bigger hole between the two for passing the wire
And mark the same hole's inside the box from left side . Attach the wire to wire to bulb holder and screw up the wooden block and bulb holder.
STEP 4: Step 4 : Making the Lock and Handle
FOR LOCK :
As I was having trouble keeping the box close I decided to make lock for it so it remains shut when it is on.
So I used some leftover cardboard to make it. cut out the pieces of cardboard as I have shown in image we need two set of it though. And assemble as shown in image.
Note : I used a small sick to use it as handle for slider mechanism.
FOR HANDLE :
Take a cardboard strip and use a scale or ruler to fold it as marked on it to make a handle and stick it with glue gun
