Introduction: How to Make a Gel Ice Pack
Have you ever got injured, and prefered not to a bag of peas of piece of uncooked meat to soothe your pain? Fear no more, this instructable for creating a gel ice pack at home will solve all of your problems!
You will need:
2 Ziploc Freezer Bags
Rubbing Alcohol
Water
Disclaimer: Rubbing Alcohol can be dangerous if consumed in large quantities, and can cause irritation to your eyes. Infants and toddlers can pull a bag over their heads and suffocate when they are unable to get them off. Take careful caution when creating your ice pack, and keep the supplies away from children.
Also, I have found that Ziploc bags work best for the ice pack, sometimes the generic brands are not as strong.
Step 1: Add Water and Rubbing Alcohol
Fill the plastic freezer bag with one cup of rubbing alcohol and 2 cups of water. For a less dense gel, reduce the amount of water to 1 cup.
Step 2: Remove Air
Try to get as much air out of the freezer bag before sealing it shut, then put it inside a second freezer bag – this way there is less chance of a leak.
Step 3: Freezing the Ice Pack
Let the gel pack freeze for about 2 to three hours. The differences in the freezing points of the rubbing alcohol and water will prevent the solution from freezing and instead give a gel texture.
Step 4: Additional Notes
If rubbing alcohol is not available, dish washer detergent, hair gel, corn syrup or salt can also be used in the same proportions.
11 Comments
6 years ago
I have several sizes made. They are great. They are so pliable so easy to get them in the position you need them in. Like curved, etc. I will never buy one.
Reply 4 years ago
Can i ask which additional substance you used that they are very flexible? Rubbing alcohol?
Question 4 years ago on Step 2
Hello,
Thank you for your great instructions to make an ice pack.
You said the same amount for other substances, so i was wondering how much salt should be in a cup ?
And which of substances you recommended makes my ice pack to be most flexible?
6 years ago
Why you need to put the alcohol? when you put the alcohol with it takes longer to thaw ?
Reply 5 years ago
Rubbing alcohol keeps pack from freezing solid. Sometimes for my cooler I do this process with water alone, but if you want an ice pack that is flexible, add the rubbing alcohol.
8 years ago
Might give this a try for my dickie knee. Any tips re getting the first zip-lock bag to fit in the second?
Reply 6 years ago
Yes, put the small filled bag into a larger sized bag.
6 years ago
I made mine in a quart sized bag, cut an old towel to fit so it would completely wrap, then put the whole thing in a gallon bag. I have a Seal a Meal type thing, so I was able to cut/seal the outer bag pretty snugly, so the towel won't come unwrapped
6 years ago on Introduction
I'm confused, where does the Dawn come in?
Reply 6 years ago
the dawn is just a subittude if you couldn't get your hands on any rubbing alcohol
8 years ago
You can get a lot of air out of the bags by slowly immersing them in a sink full of water. Start with the bag mostly closed, lower it in, the water pressure uniformly squeezes the bag.
