Introduction: How to Make a Glow Table
Wanted to make a glow table for my patio. Decided to use an old picnic table to see the results before I invested in wood to build a table. I also had to use silicon caulk to fill the the gaps between boards.
1.Table 2. glow powder 3. two part epoxy 4.clear coat 5.router
Step 1: Prepare Table
Since I used an old table I sanded the table top. I then routed out 1/2 in. random spots to add the glow powder-epoxy solution.
Step 2: Adding Mixed Solution
Following the epoxy directions, i mixed the two parts together and added the glow powder. I then poured it into the routed out areas. Once cured I wet sanded the over flow
Step 3: Build Up Edges
Once the curing and sanding was done I added trim around the table apx. 1/4 in higher than the table top. I than poured the clear coat over the entire table top.
Step 4: Results
The glow powder is activated by sun light. Here are pictures of my table at dusk and after dark. So excited how it turned out!
Step 5:
