Introduction: How to Make a Hammer
I made a hammer which is a tool that can be used in blacksmith and to destroy things, the reason I made it is because I like the idea of blacksmith.
- A computer
- autodesk inventor
- a 3D printer
Step 1:
you want to click start 2D sketch and make a rectangle with the dimension (on the top bar of sketch) and top 12in and length 8in.
Step 2:
Then you want to extrude it by 8in (On the tap of 3D model)
Step 3:
You then want to click on "fillet" and fillet the both sides of the rectangle by 1.2 in.
Step 4:
Now you want to fillet at 4 angles of the rectangle by 0.5 in
Step 5:
You want to dimension the circle with the sides of the rectangle by 4.5 on the left side and the bottom 3.45
Step 6:
Make 2 rectangles with an area of .400 in and 1in apart from the edge of the rectangle and cut (extrude) by 1in.
Step 7:
You want to make a circle in the middle and dimension it by 2.400in and then extrude by 12.
