Introduction: How to Make a Hand Bag From a Tank Top
I was shopping in Wally’s World and I saw this pretty flowered Tank top on clearance. I knew I could create a great hand bag with it so for $1.50 I bought it and took it home. One day when I was on a sewing craze, I turned it into a wonderful hand bag. So this is how I made it.
Step 1:
Supplies:
Tank top
Sewing machine
Thread (matching or contrast)
Scissors
¼ inch elastic
Straight pins
Tank top
Sewing machine
Scissors
¼ inch elastic
Straight pins
Step 2:
I laid the tank top out on a smooth surface. I realized that the back of the top was higher than the front.
Step 3:
So I folded the top in half, length wise,
Step 4:
and cut away the extra material. I was excited because this meant that I would be able to add a pocket to the outside of the bag.
Step 5:
I clean finished the edge and sewed it down so that it would match the front of the tank.
Step 6:
Next I refolded the tank so that the arm holes became the handles of the bag.
Step 7:
With the small piece of material, I had cut off, I cut a pocket and pinned it to what would be the front of the bag. I then sewed it down. This pocket is large enough to hold my cell phone.
Step 8:
Next I turned the tank inside out and folded up the bottom, about 4 inches. I marked the places I wanted to sew lines that would create pockets in the bottom of the bag. I made sure I didn’t sew a line up the center of the pocket I had sewn on the outside of the bag.
Step 9:
To sew these lines so that they wouldn’t come loose at the top of the line, I sewed a little triangle. To make this triangle, I stopped 3-4 stitches from the end, turned a 45° angle (+/-) and sewed 3 stitches, turned the material to parallel to the edge, sewed 6-7 stitches, turned to another 45° angle and sewed back to the main line, sewed back and forth a few stitches and then cut the tread.
Step 10:
I decided that I wanted the bottom of the bag gathered, so I zig zagged stretched elastic along the bottom seam. Instant gathering.
Step 11:
Turn the bag, right side out and the bag is done.
Step 12:
I added a crocheted flower for adornment. Yeah it looks great. Enjoy!
