Introduction: How to Make a Harry Potter Wand
Hey guys in this instructable I will show you how to make a harry potter inspired wand with a mini wood lathe, this project is for beginner to intermediate lathe skill, here is what you will need:
a wood lathe
lathe tools
black and brown wood stain
60, 80, 120, 400 grit sand paper
some beeswax
and a dremel tool with a cutting attachment
Step 1: Making the Wand
first if you don't already a round dowel you will need to shave it down to a cylinder, once it's down to a cylinder use the parting tool to bring it down to the diameter you want, then you work on the wand handle, once the handle is where you want it start tapering down the wand stem to a blunted point, be careful at this point because the wood may start chattering and it is possible that it could break, so I would use sandpaper to bring it to the point of where you want it, then use the stain to make it the colour you want, then let it dry, once it's dry at this point you can use beeswax to seal the wood or some other wood sealant, then using a dremel cut off both ends of the wand then sand those ends down and your done
Thanks for reading
