Introduction: How to Make a Headphones Stand
If you want to make a headphone stand like this one you'll need:
-A piece of Cold roll (About 20 cm)
-A piece of plain metal (About 5 cm x 20 cm)
-Thick wire
Step 1: The Supplies
Step 2: The Base
Firts let's find the center of our cold roll bar and make two holes at the same distance, then with the wire let's make an "U" shape for the base support.
Step 3: The Headphones Support
You'll need to solder this you can have help from a magnetic arrow like the one I use so it stays straight, after that you can file the solder so it look cleaner and much more professional
Step 4: The Holes for the Support
Like in the step behind you must find the center and make some holes for the wire that supoprts the headphones
Step 5: The Support
For making the suport you're going to make another "U" shape like this one, the part that looks going up is for the headphones not to fall off the base
