Introduction: How to Make a High Fashion Specular Reflector
-RICH MEADE
Step 1: What You’ll Need
What you’ll need :
- 24×36″ Poster Frame ($10) These come in all sizes, but you need the ones with plexiglass fronts, easily found at any superstore
- Duct Tape ($1.50) Also found at the superstore. You know the saying, if you can’t Duck it…
- Scissors ($1.50- $400) Supersharp hair styling shears are preferred, but you can use a $1.50 pair too.
- Emergency Camping Blanket ($4) The key ingredient, found at pretty much any store that has a camping section.
Step 2:
Don’t throw anything away (except the shrink wrap that came on the frame).
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Well when used in direct sun, the mylar will reflect the light extremely well. It has an almost mirror-like quality to it, similar to reflections off of rippling water. The emergency blanket provides a unique characteristic that a clean sheet of mylar won’t have. The folds and variations caused by the packaging break up the light just enough to give it that “rippled water” look. Whereas the clean sheet of mylar will just make one or two streaks of light. Below are some examples of what you can do with this reflector. With each photograph I turned, bent, or twisted the reflector slightly just to give some different effects.
Step 10:
As you can see there is a significant difference in the intensity and shape of the light between our freshly made Specular Reflector, and the basic fold up silver reflector. The “Shiny Board” is a bit tricky to get used to because it does, by design, create hotspots on the subject, as well as create very hard shadows. However, that is what I like about it, it’s a quality of light that most people are afraid to use because of it’s unforgiving nature, but I think the results are worth the extra few frames to get that hot spot in just the right area. But that’s not all! Not only do we have the optional white fill that we built in, you can also intentionally “distress” the plexiglass. By either applying dulling spray or taking the time to painstakingly scratch up the front of the plexiglass. This will soften/diffuse the light that comes off of the board. The best part is, it’s still more intense than the average fold up silver reflector because of the Mylar’s reflective properties. That means you can throw fill in from greater distances than you normally could with the basic reflector.
Below are a few shots that the “shiny board” was used on.
So the next time you are in a strange city, and need a little extra light, consider the Shiny Board option.
I mean, for $15 and about 15 minutes.
You can have a really unique and versatile reflector that you won’t have to pack with you nor feel guilty about leaving behind.
Do you have any similar DIY ideas for travel? Let us know in the comments below!
You can see here and follow Rich Meade : http://bit.ly/1fPv7c7
Reda Izo, Motion Designer, Photographer.
Want to see more ? Follow me, and stay tunned !
my Instagram
