Introduction: How to Make a Homeschooling Area
In this part of the build, I go over the steps I took in making the school booth seating area.
The dimensions of everything, were determined by the size of the old lounge cushions that we had.
Made from pallet wood and non-structural pine.
Step 1:
This is how we were previously set up to do our schoolwork,
One would sit up on the day bed that is built into the bench
and the other one preferred to sit on the cushions on the ground.
Step 2:
I started by cleaning up the area.
Step 3:
Then moved on to boxing in the side of the bench.
This will act as a back-rest for the seating area on the right hand side.
Step 4:
Then I covered in the bottom half of the door.
Step 5:
Moving on to the frames for the seats.
Step 6:
I used lengths of 70 x 35 that I ripped down the center.
I do this to save on space and money.
Step 7:
For the lift up seat, I simply ran 2 lengths of timber at the front and back of the seat area.
Step 8:
then attached the palings to only those two pieces.
Step 9:
keeping the top of the seat free from the base and thereby utilizing the free space underneath for storage.
Step 10:
Moving on to the back-rest of the seat on the left hand side.
Step 11:
I started by making a simple square frame. Laid the frame on a flat surface and start attaching your palings.
Step 12:
keeping one edge flush.
Step 13:
Use a straight edge to precisely mark your holes with the frame below it.
Step 14:
Pre-drill your holes only going through the paling and not through the frame.
Step 15:
Give the holes a chamfer, then attach them.
Step 16:
Run the circular saw over the remaining edge to remove the excess length.
Step 17:
Give it a stain, then attach it to the wall.
Step 18:
For the floating floor, I push the pre-cut boards up under the kick-board of the first seat.
Step 19:
Then add the kick-board of the other seat directly on top, holding the floating floor in place.
Step 20:
Moving onto the base of the seat on the left hand side, it is simply a mirror image of the other side.
Step 21:
Build the lift up seat the same way as we did for the other side.
Step 22:
The reason why I gave the seats an overhang is to increase the leg room.
Step 23:
Now to build the wall to contain everything.
Step 24:
I use the full width of the 70 x 35 this time. I wanted the added strength, since we are constantly climbing up over it, and I prefer the chunky look.
Step 25:
I covered the inside wall in first and got plenty of help from the boys.
Step 26:
By this stage of the build we had already started using it for our schooling.
Step 27:
For the outside of the wall, I ran the palings vertical. It just helps separate it from the back wall
and break up all those horizontal lines.
Step 28:
And now to stain it. I used Cabots water based in the color New Jarrah.
Step 29:
part 2 of this build is the table, table storage and world map on top.
