Introduction: How to Make a Human Following Robot With Arduino
Human following robot sense and follows human
Step 1: Get the Tools
Get the tools like :
Ultrasonic sensor
Sensor
Arduino uno
4 gear motors with wheel
Servo
Battery and battery case
Motor driver
Jumper wires
Chassis
Ultrasonic sensor
Sensor
Arduino uno
Servo
Motor driver
Jumper wires
Chassis
Step 2: Connecting
Connect every equipment to motor driver.
Connect motor driver to arduino.
Step 3: Code
#include
#include
#include
#define RIGHT A2
#define LEFT A3
#define TRIGGER_PIN A1
#define ECHO_PIN A0
#define MAX_DISTANCE 100
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor Motor1(1,MOTOR12_1KHZ);
AF_DCMotor Motor2(2,MOTOR12_1KHZ);
AF_DCMotor Motor3(3,MOTOR34_1KHZ);
AF_DCMotor Motor4(4,MOTOR34_1KHZ);
Servo myservo;
int pos =0;
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
myservo.attach(10);
for(pos = 90; pos <= 180; pos += 1){
myservo.write(pos);
delay(15);
} for(pos = 180; pos >= 0; pos-= 1) {
myservo.write(pos);
delay(15);
}for(pos = 0; pos<=90; pos += 1) {
myservo.write(pos);
delay(15);
pinMode(RIGHT, INPUT);
pinMode(LEFT, INPUT);
void loop() {
// put your main code here, to run repeatedly:
delay(50);
unsigned int distance = sonar.ping_cm();
Serial.print("distance");
Serial.println(distance);
int Right_Value = digitalRead(RIGHT);
int Left_Value = digitalRead(LEFT);
Serial.print("RIGHT");
Serial.println(Right_Value);
Serial.print("LEFT");
Serial.println(Left_Value);
if((Right_Value==1) && (distance>=10 && distance<=30)&&(Left_Value==1)){
Motor1.setSpeed(120);
Motor1.run(FORWARD);
Motor2.setSpeed(120);
Motor2.run(FORWARD);
Motor3.setSpeed(120);
Motor3.run(FORWARD);
Motor4.setSpeed(120);
Motor4.run(FORWARD);
}else if((Right_Value==0) && (Left_Value==1)) {
Motor1.setSpeed(200);
Motor2.setSpeed(200);
Motor3.setSpeed(100);
Motor3.run(BACKWARD);
Motor4.setSpeed(100);
Motor4.run(BACKWARD);
}else if((Right_Value==1)&&(Left_Value==0)) {
Motor1.setSpeed(100);
Motor1.run(BACKWARD);
Motor2.setSpeed(100);
Motor2.run(BACKWARD);
Motor3.setSpeed(200);
Motor4.setSpeed(200);
}else if((Right_Value==1)&&(Left_Value==1)) {
Motor1.setSpeed(0);
Motor1.run(RELEASE);
Motor2.setSpeed(0);
Motor2.run(RELEASE);
Motor3.setSpeed(0);
Motor3.run(RELEASE);
Motor4.setSpeed(0);
Motor4.run(RELEASE);
}else if(distance > 1 && distance < 10) {
Motor1.setSpeed(0);
Motor2.setSpeed(0);
Motor3.setSpeed(0);
Motor4.setSpeed(0);
#include
#include
#define RIGHT A2
#define LEFT A3
#define ECHO_PIN A0
Servo myservo;
int pos =0;
void setup() {
Serial.begin(9600);
myservo.attach(10);
myservo.write(pos);
delay(15);
myservo.write(pos);
delay(15);
myservo.write(pos);
delay(15);
void loop() {
delay(50);
Motor1.setSpeed(0);
Motor2.setSpeed(0);
Motor3.setSpeed(0);
Motor4.setSpeed(0);
Motor1.setSpeed(0);
Motor2.setSpeed(0);
Motor3.setSpeed(0);
Motor4.setSpeed(0);
