Introduction: How to Make a Joule Thief - Boost Converter
Joule Thief allows to use almost all of the energy of a single cell or a single cell battery.
Click to subscribe to my YouTube channel ► http://bit.ly/rudyexplor (thanks)
Thus, the circuit Joule Thief permits to increase the voltage of the source (battery, battery) above the minimum voltage required to operate the device connected to it. We can use the batteries and rechargeable batteries for longer, even when the voltage of the latter drops below their voltage, the joule thief standpipe. Joule Thief will extract the last available battery joules or acbcumulateur, hence its name!
The joule (symbol: J) is a unit derived from the international system for quantifying energy, 1 joule is the energy required to raise one apple (100 grams) of a meter in the Earth's gravity field.
How Joule Thief for example: at the entrance, it was 1.5 Volts * 1.0 Ampere = 1.5 W, the output was 3.0 Volts 0.4 Amps * = 1.2 W 0.3 W (losses)
To make a Joule Thief you will need the following equipment :
- An LED 3v
- AA 1.5V battery
- Resistance of 500 Ohms 2 Ohms
- An NPN transistor
- A ferrite core
- 60 cm double wire
All my videos are translat with the subtitles. If you want to make changes to the subtitles of the videos. (I do not necessarily speak very good English) Go to the video that you want to contribute closed captions to. In the player, select the gear icon. From the drop-down menu, select Subtitles / CC> Add subtitles or CC. You can then modify them
Step 1: Ferrite Cores
We will therefore surrounded with a minimum of 15 rounds Around of the Ferrite Core.
Then we will connect two different wire : a blue and red that will be connected together.
Step 2: Resistor
We will connected : one of the two wire remaining to resistor.
And of the resistor at the "Base" of transistor.
Step 3: Transistor
Then, connect the "Collector" to the remaining wire of the Ferrite Core.
And the remaining wire of the Ferrite Core at the positive (+) of the LED.
Then connected the negative (-) the battery on "Emitter" of transistor.
And "Emitter" at (-) negative of the LED.
Step 4: Battery
And finally we will connect to positive (+) of the battery with the two wires that we have grouped first.
So you know now how to increase a Direct Current.
Pretty cool ! Is not it?
I hope you enjoyed this instructable.
If you want to see more,
you can visit my YouTube channel (please subscribe) : http://bit.ly/rudyexplor
RudyExplor
Circuits Contest 2016
4 Comments
7 months ago
Cool thanks u
5 years ago
nicely laid out for even me to understand wanting to build random things and looks like i came to the right place
5 years ago
Thank you for your message.
You can also visit my YouTube channel: https://goo.gl/cV53ES
5 years ago
that's the best description that I ever read here. I wanted to build one too, but I couldn't work with the Instructable which says "use 2 nanoseconds of wire", since I dunno how to calculate it. I could've used Google, but man... I was way to lazy :)
