Introduction: How to Make a Key Fob From Loose String
You can use any old string you have laying around, old rope, paracord, even shoe laces!
Step 1:
Place your cord/shoelace/string through your keyring so that on either side of the ring is only one piece of string/cord/shoelace
Step 2:
Pick the length for your key fob. Once you've decided how long the fob should be, make a loop from the left strand over the right.
Step 3:
Wrap the right side strand over the loose left end
Step 4:
Bring it around the back of your two strands and through the loop we made in step 1. This will create a loose knot.
Step 5:
Pull the knot tight.
Step 6:
Using the right strand of your cord, make a loop like before
Step 7:
Wrap the left strand around the loose end of your loop, around the back and through the loop on the right
Step 8:
Repeat steps 3-7 Until you reach the desired length.
Step 9:
Cut the extra string from your fob.
Step 10:
Burn the edges with a lighter to seal the fob together. You may, with a damp finger press the ends closer to the knots for a cleaner look.
