Introduction: How to Make a Knot Bracelet
Do you ever get bored and think of a craft that will take some time and boredness away? This is teaching you how to make a knotted bracelet. This is a fun craft you can do if you ever get bored or there is nothing for you to do.
Scissors, multiple colors of string, and some tape
Step 1: Get Your Preferred String
Get the desired color of the string you want to do this design with. You can use as many colors as you would like. You can use whatever color you prefer as well.
Step 2: Cutting the Strings
Cut all of your strings to the same length and to the length you prefer.
Step 3: Tie All the Strings Together
After cutting the strings to the desired length you are going to tie them. Tie all of the strings together. Tie them together in a upwards knot.
Step 4: How to Start the Bracelet
Take the first color of the row you want. Make a shape like a four and do that to every color until the end. After that switch to the next color a line underneath.
Step 5: Repetition
Do the last step for a little while of time. Make sure you are keeping the routine and keeping the color pattern the way you started it. Again by just making that four shape and pulling up and tight.
Step 6: Color Switches
Make sure you are keeping the routine and keeping the color pattern the way you started it. Making sure you are switching colors and applying pressure to keep the knots tight.
Step 7: Finishing the Bracelet
Now to end the bracelet. To finish the bracelet, you want to take all the excess string, and tie it to where the knots will not come out. You are going to take the excess string and either cut it, or you are going to keep it on the bracelet. Finish the bracelet until you get the desired length of your bracelet or until your string runs out.
Step 8: Braided End
If you want your bracelet to end a different way, you can always end it by adding a braided style to the end of your bracelet. The first thing you want to do is find how many strings you need. If you have six strings, divide them into two sections of three. Start the braid and when coming to the end, add a knot and you'll be finished with that type of style.
Step 9: Tying It On
To tie a bracelet your want to make a knot suitable for keeping your bracelet on, and tie your string together with the other side of the bracelet.
Step 10: Tying the Braided Style
To tie the braiding style to whatever you are tying it to, you must make sure your knots are tight. You can take the first loop you made on the beginning of the bracelet and put the braids through there. Pull somewhat tight to where it won't fall off. Make a knot and when you are finished with that, you are all done!
Step 11: Ending Results
Here is what the bracelet should look like braided and unbraided when finished!
