Introduction: How to Make a Life Size T Rex Hand Wall Mount
This is a full-size T-Rex hand wall mount.
- Template
- 4” diameter tube
- 2 cardboard toilet paper roll
- 2 plastic knives
- Duct tape
- 2 pages of newspaper
- Paper mâché
- Paint
Step 1:
Print this template.
Step 2:
Cut the 4” diameter tube to the length you want the T-Rex arm.
Step 3:
....cut a paper towel tube in half to make two T-Rex fingers...
Step 4:
Using the template, cut the T-Rex fingers to size.
Step 5:
Attach the fingers to the arm and use tape to secure.
Step 6:
Add plastic knives to the small tubes using tape.
Step 7:
Make sure fingers are attached securely. Secure the smaller tube with knives attached to the larger tube with heavy tape.
Step 8:
Add newspaper between the fingers to create a rounded hand.
Step 9:
Add some tape loosely over the newspaper to attach to the larger tube.
Step 10:
Cover all of the paper with tape.
Step 11:
Pinch the top of the smaller tube around the plastic knife. Secure with tape.
Step 12:
Start adding paper mâché to the larger tube.
Step 13:
Add paper mâché between the fingers.
Step 14:
Apply paper mâché to the plastic knives.
Step 15:
Working down add paper mâché to the smaller tubes.
Step 16:
Be sure to cover all areas with the paper mâché.
Step 17:
Let dry overnight. Repeat the paper mâché application for a second coat. Let dry overnight.
Step 18:
Paint using colors you chose. Let the paint dry overnight.
Step 19:
Your T-Rex arm is finished!! Attach to the wall and enjoy!!!
