Introduction: How to Make a Marble Cannon
The marble cannon is meant to hit a target that is 2 to 5 meters away in distance and one meter off the ground in height.
Step 1: Step 1: Gather Materials
- One 50x50 cm block of wood
- Two pieces of PVC pipe
- Two rubber bands
- Two one and a half inch pieces of wood and two one half inch pieces of wood
- Two nuts and bolts
- One piece of angled wood
- Many nails
- 2 Wooden dowels
- 3 Metal pieces
Step 2: Step 2: Asemble the Pipe Together
- Measure out one foot of PVC pipe and cut it
- Take a wooden dowel and slide it into the PVC pipe then screw it into the pipe
- To hold the rubber bands there needs to be a zip tie near the bottom of the PVC pipe
- The rubber bands will be connected to the screw and a latch
Step 3: Step 3: Assemble the Two Pieces of Wood to the Base
- Cut the base on one side an inch and a half to each side
- Take the one and a half inch pieces of wood and place them where the cuts are
- Take two nails on each side and drill them in
- Then take the half inch wood and staple them in the middle of the base. When doing this, leave a half inch between the two pieces of wood in the middle
Step 4: Step 4: Assemble the Pipe to the Wood
- Cut a twelve inch PVC pipe
- Put a wooden dowel in the PVC pipe for stability
- Drill two nails into the end of the PVC pipe
- Take two nails and drill them into the PVC pipe but not all the way
- Put metal on the PVC pipe to latch it to the two thicker wood pieces with two nails on either side
- Then take the angled wood and slide it in between the half inch wood pieces
Step 5: Step 5: Final Steps
- Drill a metal piece into the middle of the twelve inch PVC pipe with two nails
- After the base and the PVC pipe is finished take the one foot pipe and slide it into the piece of metal that was just placed
- Then adjust the angle wood to the angle that is needed
Step 6: Step 9: Calculations
- Figure out the three angles that were needed for the trials
- Then, figure out the time through the time calculation that was needed in the air rocket lab
- After figuring out time, use the third kinematics equation to find Vox and Voy
- In trial one Vox was 5.12 m/s and Voy was 101.4 m/s
- In trial two Vox was 5.17m/s and Voy was 88.6m/s
- In trial three Vox was 6 m/s and Voy was 51.3 m/s
- After finding Vox and Voy you must complete the pythageorean theorem to find the hypotenuse
- Trials one through three were 101.5 m/s, 88.8 m/s and 51.6 m/s
4 years ago
I'm sure my nephews would love this! I'm not sure the house would survive :)
