How to Make a Microbial Fuel Cell (MFC) Using Mud
35,806
443
37
Introduction: How to Make a Microbial Fuel Cell (MFC) Using Mud
About: We make fun and educational STEM kits that let you play with microbes. Create electricity from the bacteria living in mud, or make bread while racing yeast!
The MudWatt microbial fuel cell (affectionately dubbed the "Dirt Battery") is a device that uses bacteria to convert the organic matter found in mud into electricity. This Instructable will walk you through making your own microbial fuel cell using any MudWatt Science Kit.
To make a MudWatt, you will need:
How the MudWatt Works: The MudWatt is a fun and educational science kit that uses the micro-organisms naturally found in soil to generate electricity. Although invisible to the naked eye, these microbes, with bodies one-tenth the thickness of a human hair, live throughout virtually all soil and sediment on the planet. Among these diverse communities of microbes are particular species that have the unique ability to release electrons outside their bodies as part of their respiration process.
The MudWatt harnesses this remarkable ability by providing these mud-based microbes with two conductive graphite discs, called an anode and cathode. The anode is placed within the mud where the electrogenic microbes can grow, while the cathode is placed on top exposing it to oxygen in the air (see MudWatt diagram below).
Step 1: Making Mud
Put on gloves and find 3-4 handfuls of soil or swamp goo--the smellier the better! Make sure your soil is saturated but not soupy by either adding or pouring off water. Optional: Add extra nutrients to your soil, such as MudWatt packaging, shredded paper products, or food from your fridge.
Key notes: Avoid using soils with little white balls (perlite) which aerate the soil. The bacteria that power the MudWatt are anaerobes that need an environment without oxygen to build healthy communities.
Step 2: Making Electrodes
Bend both wires 90° where the plastic sheath ends. Straighten out the bare end of the wire. The green wire will be used to make the anode, and the orange wire will be used to make the cathode. Insert the bare end of the anode (green) wire into the side of the thin felt disc while wearing the gloves provided. Try to keep the wire from exiting the felt. Repeat this step with the cathode (orange) wire and the thick felt disc.
Step 3: Assembling
Pack an even layer of mud into the bottom of your container, at least 1cm deep. Place the anode (green) you constructed in Step 3 on top of the mud, pressing it down firmly to squeeze out air bubbles. Fill your container with more mud, at least 5cm deep, pressing down firmly to squeeze out air bubbles. Let your mud rest for a few minutes and drain any excess liquid. Finally, place the cathode (orange) gently on top of the mud. Do not cover the cathode with mud.
Step 4: Lidding (for MudWatt Kits That Come With Vessels)
If your kit came with the MudWatt Vessel:
Remove your gloves and attach the Hacker Board into the indentation on the lid. Pass the electrode wires through the lid. Facing the semicircular indentation, the cathode (orange) should be on the left and the anode (green) on the right. Now press the lid down onto the jar to snap it into place.
Step 5: Closing the Circuit
1. Bend and connect the cathode wire (orange) to ‘+’ and anode wire (green) to ‘-’ on the Hacker Board.
2. Connect the long end of the blue (10μF) capacitor to pin 1 and its short end to pin 2. You may need to bend the wires so that they fit snuggly.
3. Connect the LED ‘s long end to pin 5 and its short end to pin 6.
That’s it! You should start seeing the LED blink after a few days, once your MudWatt has developed a healthy community of microbes!
What do these components do?
Hacker Board: The Hacker Board takes the low voltage and low current coming from the MudWatt and converts into short bursts of higher voltage and higher current.
Capacitor: The Capacitor is a little energy storage component. It is able to build up energy as power comes in from the MudWatt, and then discharge that energy in a quick burst to blink the LED.
LED: The Light Emitting Diode (LED) takes the electrons being discharged by the capacitor and converts those electrons’ energy into light energy.
Step 6: Measuring Microbes and Power Output
Download the MudWatt Explorer App on the App Store or Google Play. You’ll be using it to measure, record, and analyze your MudWatt data in the few next steps!
Step 1: Ready, Aim...Measure!
Once your MudWatt’s blinker is blinking, open the MudWatt Explorer App and select Measure from the main menu. Line up the blinker in the target on your screen and the App will automatically measure your power and your population of electric bacteria!
Step 2: Record & Analyze Multiple Measurements
Record several measurements by using the Record button on the Measurement screen, and go to the Analyze section of the app to see how your MudWatt functions over time!
Step 3: Discover a Hidden World
Use your power readings to unlock chapters of a fun and educational comic following Shewy, the Electric Microbe. Discover the magic of microbes as Shewy explores this complex, muddy world.
Step 7: A Closing Note and DIY Resources
Thanks so much to everyone that has commented on our post! When Instructables first invited us to post about the MudWatt, we weren’t sure if it was the right fit, since it is indeed a product, and we were worried our Instructable would end up sounding like an infomercial. But we decided to do it because the MudWatt is designed to be a DIY MFC kit, after all. While we are of course excited when people buy our products, we’re also very excited when we inspire people to pursue their own creation and experimentation. Many people have requested more info for creating their own MFC using off-the-shelf parts. This is completely possible to do, and we’ve provided resources for that below. However, we’ve found that making a true MFC with off-the-shelf components is significantly more expensive than purchasing our components. The MudWatt actually started out using off-the-shelf components, but we've managed to get the price down by ordering materials in very large quantities and processing them ourselves.
We've seen several posts about DIY MFCs in the past, but we've found that these projects include the use of metal meshes, metal brushes, copper wire and other materials that corrode in harsh soil environments. Using these corrosive materials means that you're making a corrosion battery instead of an MFC. That corrosion often occurs at the junction between the electrode material and the wire. This junction can be sealed with epoxy, but this is very difficult to do in practice, especially if you're using high-surface-area or porous electrodes, which you'll need if you want to produce any significant power. The funny thing is that this corrosion will actually produce some significant power, which can be very easily mistaken to be coming from microbial activity.
For making your own DIY MFC, here are some places you can find non-corrosive materials:
Carbon electrodes: http://fuelcellstore.com/fuel-cell-components/gas...
Titanium Wire: http://fuelcellstore.com/fuel-cell-components/gas...
Charge-pump chip (for power an LED/electronics): S-882Z24-M5T1G
We encourage you to use the MudWatt as a launching point for your own research, and we'd be thrilled if you're able to create a true MFC using off-the-shelf materials at a cheaper price. Happy experimenting!
Be the First to Share
    • Stone Concrete Cement Contest
    • First Time Author Contest
    • Pets Challenge
      Pets Challenge
    37 Comments
    SHOE0007
    SHOE0007
    1 year ago
    I tried this with soil bacteria graphite rods and salt and bacteria. It worked at first but produced very low voltages and I tried amplifying it with a DC to DC converter. It failed. Even graphite-aluminum soil batteries gave semi good results. However connecting 3 batteries increased the resistance to enough that the DC converter could not opperate. Difficult to scale up but possible.
    Nikhitha98
    Nikhitha98
    Question 4 years ago on Introduction
    What is the thing used as anode and cathode? Both are graphite discs?
    Magical Microbes
    Magical Microbes
    Answer 4 years ago
    Yes, both the anode and cathode are made of conductive graphite fiber felt. Hope that helps!
    HORSENZEBRA
    HORSENZEBRA
    5 years ago
    Works well. Thankyou
    SHOE0007
    SHOE0007
    5 years ago
    Good attempt for alternative energy. Difficult to scale up and may work better with oxygen exposure. Of course you would have to protect the amplifier from a potential high gain of power. There should be better models out there. This is what I got.
    enzymeandco
    enzymeandco
    5 years ago
    Hi guys !
    We got a Mudwatt blinking 1 time/sec here in Cardiff on good old Welsh estuary mud, only 3 days after setup. We are happy !
    We tried to order some Seiko S-882Z charge pumps to build some other MFCs, but it seems that the production is now discontinued.
    How are you dealing with this issue to continue to produce your HackerBoards ?
    Do you have a new reference to advise ?
    Thanks in advance for your answer !
    Merinoide
    Merinoide
    6 years ago
    Firstly, sorry by my english, I know that it not the best.
    I have two cuestión:
    1) Why use the filter more narrow like a anode? What happen or why not use the big filter like a anode, and the smoller like a cathode.
    2) It's possible make more electricity power if in the anode put more wires, like a mesh, inside of anode filter?.
    Thank very much.
    Nknk
    Nknk
    6 years ago
    hi,
    I live in a very cold area. Outside everything is all covered in snow for a few months. Is it OK to collect mud sample in such conditions? Does the freezing temperature kills bacteria in the mud? I tried this experiment with my own MFC, but the voltage is negative (the connections are all correct!). What could be wrong? I'm wondering if the cold/ freezing temperature kills bacteria in the mud/ sludge? If so, where I can get the mud from? Please let me know! Thank you!!
    Magical Microbes
    Magical Microbes
    Reply 6 years ago
    Hi Nknk,
    Thanks for your message. Yes, temperature has a big impact on microbial respiration rates, and therefore power in an MFC. Freezing temperatures shouldn't kill the bacteria completely, but it will put them in a pretty dormant state. The best thing to do is to warm up the soil to around body temperature and put some shredded up paper in the soil near the anode. This should help get the bugs going again. As for the negative voltage, hmm... I would make sure that there are no air bubbles near the anode, and no excess water near/above the cathode.
    Hope this helps!
    ThaDee
    ThaDee
    6 years ago
    +1
    Like. Been following the PFC but haven’t built anything
    (yet).
    So you just need to poke the wire in the graphite plate? Or
    is the one provided in the kit special somehow?
    tinee pika
    tinee pika
    Reply 6 years ago
    one is provided
    Magical Microbes
    Magical Microbes
    Reply 6 years ago
    That's all you need to do! Our wire is titanium (won't corrode, which is key to making a MFC instead of a corrosion battery), and the graphite plate is just graphite fiber felt. You can get graphite materials from http://www.fuelcellstore.com/ and can experiment with using carbon fiber building materials, as well.
    ThaDee
    ThaDee
    Reply 6 years ago
    Been wondering ever sins I first found PFC(plant
    fuel cells) how to make the anode and cathode. So super! Tnxz!
    tinee pika
    tinee pika
    6 years ago
    by the way i have the kit and oe is provided so you dont have to worry to buy oe and in the kit they call it the hacker board and every thing above is provided in the mud watt classic kit
    liz_hammack
    liz_hammack
    6 years ago
    Looks like a great project to teach kids about alternative energy sources
    3967
    3967
    6 years ago
    how practial is this when you scale up, to produce larger output.
    How much space to you need for 100 Watthours or 1000watthours ?
    Magical Microbes
    Magical Microbes
    Reply 6 years ago
    MFCs are notoriously difficult to scale, with the power density (Watts per square meter of electrode surface area) decreasing as electrodes get larger. The reason for this is still under debate. The most effective thing to do is to connect multiple smaller MFCs together in series of parrallel to get greater voltage or current respectively. MudWatts will typically produce 50-100 microWatts, meaning that you'd need 1,000,000 MudWatts to get 100 Watts.
    3967
    3967
    Reply 6 years ago
    When the energydesinty is so low, where is the benefit over other powersources like Solar,Wind or chemical energy ?
    Magical Microbes
    Magical Microbes
    Reply 6 years ago
    Great question! MFCs satisfy an energy niche: they can meet low energy needs in remote locations and produce energy as a by-product of waste treatment.
    The military and universities install sensors deep in the ocean. The energy requirements of these sensors are relatively low and the cost of replacing batteries extraordinarily high. Microbial fuel cells are excellent sources of energy under these conditions, as they're able to continuously provide power to these sensors without the need for regular replacement. For more reading on MFCs in the ocean: https://cdn.shopify.com/s/files/1/0598/6373/files/...
    MFCs are also great technologies where waste is involved. Wastewater treatment and remediation of contaminated groundwater and soil are two examples where we can take advantage of anaerobic conditions to generate electricity in tandem with treatment. These two ubiquitous treatment scenarios provide the conditions necessary for anaerobic microbes, thus enabling microbial-based energy production (typically methane generation, MFCs currently being piloted) that turns waste back into energy, thus closing the loop!
    So while MFCs probably aren't going to power the grid like other renewables, they can reduce energy requirements of commercial and municipal-level treatment projects using existing conditions.
