Introduction: How to Make a Minecraft House
If you want to live in Minecraft luxury, click here to learn how to build a luxurious Minecraft house.
Step 1: Materials
The first step to building a Minecraft house is to get materials. To build this house, you will need...
- White Stained Glass
- Iron Gates
- Acadia Planks
- Quartz Blocks
- Quartz Stairs
- Stone Slabs
- Acadia slabs
- Cobblestone Slabs
- Cobblestone Stairs (Not on the pic)
- Stone
- Gray Stained Clay
- Minecart Rails
- Any door
Step 2: Floor Plan
After that, you need to make a floor plan for your house. (You're going to want to build in creative and find a large flat space). Build a layout with your Gray Stained Clay and make a plan that you are happy with. Now you're ready for Step 3.
Step 3: Walls and a Window
Next, build up the walls with your Gray Stained Clay until they're 8 blocks high. when you're done, grab your Acadia Planks and you White Stained Glass and cut out a 5x5 hole from the corner. Cut out an extra column and fill the outside of the window with your Acadia Planks. Then fill the rest in with White Stained Glass.
Step 4: Floors
As soon as that's done, you can start building your floors. Take your Acadia Planks and make floors on the 4th block and 8th block. On the 4th floor, keep a empty square from the edge of the window to the other edge. Place White Stained Glass on the outer edge. Afterwards, build the top floor for your balcony. Then make a layout for another wall that makes the balcony wrap around the building, making the balcony 7 blocks wide. Finish off with staircases for each floor.
Step 5: Balcony
For the balcony, use your White Stained Glass and make a barrier around the edge. Then take your stone slabs and make a roof over your balcony. Start at the bottom half on the 4th block and build 7 blocks away from the wall. Then you can cover the small building part with more slabs. Make sure that the slabs are on the top and that the slab roof overhangs.
Step 6: Entrance
Now we are going to make the entrance. For your house, make a platform of Acadia wood slabs and fill a 7x5 square. Add Cobblestone for the ground and your White stained Glass. For your stairs,start by digging out a hole that is to your desire (for your staircase). Next, dig out the incline for your staircase (again, to your own desire). Then you can fill it in with your Cobblestone Stairs and if you want, Cobblestone Slabs.
Step 7: YAY!
Now you are finished and can do whatever you want to do (Happy Dance)
skej. hrj h iirehfsgh oi iowhifu!!!!
See ya!
