Introduction: How to Make a Minecraft Nether Portal
This is a tutorial on how to build a Minecraft nether portal
Step 1: Materials
The materials you will need are:
-Obsidian (Crying Obsidian will NOT work)
-Flint & Steel or Fire Charge
Step 2: Bottom Frame
First, lay down four blocks of obsidian.
Step 3: Sides
Then place 4 blocks of obsidian up from each side of the bottom frame.
Step 4: Top Frame
Then add 4 blocks of obsidian on the top.
Step 5: Activating the Portal
After that, add flint & steel or fire charge to the inside of the structure.
Step 6: Finished!
This is what your finished product should look like! Step inside and Enjoy! Here you can come by a Bastion Remnant or a Nether Fortress. To come back just walk through the portal again!
If you want to make more Minecraft creations then check out Vianlellgova22!
Thanks for reading!
