Introduction: How to Make a Mini Bar From Jerry Can
This time I’ll show you how to make A Mini Bar From Jerry Can.
How I did it - you can check by looking DIY video or you can follow up instructions bellow.
For this project you will need:
Materials:
Jerry Can (20l)
Rubber seal (~2.5m length) https://goo.gl/ryXLwD
Small screws, bolts, washers
Wood screws
Draw lathes
Hinges
Pop rivets
1cm thick plywood
Polyurethane windshield glue
Black mat spry paint
Some clear coat for finish
Tools:
Drill and bits
Table saw/miter saw to cut plywood to size
Pop rivet tool
Cutters
Angle grinder
Rotary tool
Some marking and measuring tools
Step 1: Measuring and Marking
As a base for this build I’ll use twenty liters Jerry can a.k.a petrol canister. I think you could easily find one in your local hardware or automotive parts store.
Measured and marked door lines. To get nice and round corner shape - I used random plastic cap as a guide.
Step 2: Cutting
With angle grinder cut straight lines, and with rotary tool cut corners. Used angle grinder with flap disc to clean all burrs.
Step 3: Rubber Edge Seal
To cover all edges I used this rubber edge seal. It is flexible and nicely bends over the corners. There is no need any glue or other fixing product, because it holds very well. I bought it locally, but I’ll leave a link of equivalent product. Just in case if you want to get it on line. https://goo.gl/ryXLwD
Installation is very simple - just slide it on the edge. For me this joint looks like it was manufactured by mass production manufacturer. This is my first time when I’m working with this rubber seal and I’m really happy with result.
Step 4: Fixing Hindges
Next, marked place for hinges and drilled holes for rivets. I used rivets painted in green. Color wasn't exact same tone, but it was quite close.
Spayed all inner surface in mat black. And finished fixing pop rivets.
Step 5: Draw Latches
Time to install draw latches. Procedure is the same as with hinges - drilling holes and securing in place. The only difference is, that this time I used bolts, washers and screws instead of pop rivets.
Step 6: Making Shelf
Jerry can is done, so let’s build a shelf. I measured and cut needed parts from 1cm thick plywood. Measuring, cutting, again measuring, cutting, sanding and etc. This process was really boring - so I’ll show you only final assembly.
This shelf was specifically made with three section for dedicated items: left for soda cans, middle for glass and right one - for a bottle.
Step 7: Tweeking..
In middle section added two plywood pieces to separate glass.
I needed to unscrew one side to get enough space for clamps.
Because left section was too deep I raised it by gluing some plywood spacers and additional piece of plywood in bottom.
I glued two side holder from same plywood. They will hold 4 soda cans in a row. For finish applied two coats of clear mat varnish.
Step 8: Knobs
Made three small knobs from same plywood. They will hold glass in place and won't let them to fell out. Nailed with this type of decorative nails.
Step 9: Glueing Shelf in Place
Used polyurethane windshield glue to glue shelf inside the Jerry can. Made a lot of glue dots what ensure wide holding surface and will give a lot of strength. I don’t want to use any wood screws, because they will be visible from other canister side. So polyurethane glue was the perfect choice.
Slowly slided in, centered, gave a good amount of pressure and let it to dry. When glue was cured - removed piece of cardboard from a Jerry can back. This piece was protecting canister back from scratches entire making process.
Step 10: Result
I’m more than happy with final result. Great accent for any petrol head house, man cave or garage.
All items inside are easy accessible and at the same time secured in place while mini bar is transported.
This is a mini bar, but the same concept could be used to make storage for anything. All you need is to work on different shelving design.
Metal Contest 2017
3 People Made This Project!
- stevetheenglishman made it!
- ManuelR173 made it!
- timdekker1825 made it!
30 Comments
Question 2 years ago
Can you send me the dimensions of plywood and door?
Answer 1 year ago
Hi,Did you get an answer about the dimensions of the wood?
2 years ago
Have you got the dimensions for the inner shelving? Making something for the first time and haven’t got a lot of experience
5 years ago
very nice, but JD should be drank on rocks, not with coke. :)
Reply 2 years ago
you say that like JD is of high quality 😂
5 years ago
I have a humidor I made out of a metal ammo can (ammodor). Having seen this project, I see I now need to up my game. I can make a humidor out of one of these Jerry cans by lining it with Spanish Cedar and dividing it up with padded drawers...Can-O-Dor!
Thanks!
Reply 2 years ago
Pics?
Reply 2 years ago
Not mine, but you get the idea.
3 years ago
bravo ya lui il fait diretement son ordinateur
https://www.youtube.com/watch?v=332czR6KBW8
4 years ago
I made one! Very happy with my version.
Reply 3 years ago
Cud u send us the dimensions of plywood and door?
3 years ago
Could you please send a document with labled pics of the plywood and door measurements?
Question 3 years ago on Step 1
how far from the edge of the can did you cut for the door
4 years ago on Step 7
REALLY COOL
Question 5 years ago on Step 1
What were the measurements for the door and for the wood?
Question 5 years ago on Step 6
Hello, do you have a template for the woord ?
5 years ago
I made it! Ok for first try. The clasp side has a gap which the wood is showing a bit.
5 years ago
Where can I buy
5 years ago
.....cool so gonna make this.....cheers!
5 years ago
Absolutely fabulous!! very nicely done.
