Introduction: How to Make a Mini Lego Sherman Tank
I will show you about how to build a mini lego Sherman that will dominate the battlefield, destroying everything in its path!!!
Step 1: Materials for Your Sherman
In order to make this awesome tank, you will need
- 4 1X4 round technic pieces
- 3 2X3 pieces
- 3 1X1 sloped
- 1 1X3 piece
- 3 1X2 tiles
- 2 axle w. grooves
- 1 1X2 brick with 2 holes
- 1 1X3 tile
-1 1X2 piece
- 1 1X1 brick with 4 studs around
- 2 1X1 pieces
- 2 1X1 tiles
- 2 1X2 jumper plate
- 1 telescope piece
- 2 technic connectors
Step 2: the Tracks
First, we will be making the tracks of the tank.
Grab 2 1X4 round technic pieces and 1 axle with groove piece and put the axle into the 1X4
Step 3: The Tracks Cont.
Next, grab the 1X2 brick with 2 holes and 2 technic connectors and insert the 2 connector pieces into the 1X2.
Make sure a half of the connector piece are sticking out from each side of the brick.
Step 4: Assembling the Tracks
Repeat step 2 and then grab the pieces from step 3 and stick the other half of the connector piece into the tracks,
Do the same with the other track.
Step 5: Building the Body
First, grab 3 2X3 pieces, put 2 together and then put the last 2X3 on top, in the middle.
Make sure they are connected.
Step 6: Making the Angled Armor
Second, grab 3 1X1 sloped pieces and put them on 1 side of the body.
Step 7: Building the Tank's Back
Now, grab 1 1X3 and put it at the back of the tank.
Step 8: Making the Body Cont.
Next, grab 1 1X2 jumper plate and then put it in the middle of the tank.
Step 9: Making the Body Cont.
Finally for the body, grab 2 1X2 tiles and 1 1X3 tile and then put the 2 1X2's beside the jumper plate and the 1 1X3 goes behind the jumper plate.
Step 10: Making the Turret
First, grab 1 1X1 brick with 4 studs around it and 2 1X1 pieces and put the 2 1X1 pieces opposite of each other, on the 1X1 brick with 4 studs.
Step 11: Making the Turret Cont.
Second, grab 1 1X2 piece and put it on one side of the 1X1 brick.
Step 12: Making the Turret Cont.
Third, grab 1 1X2 tile and put it on the 1X2 piece.
Step 13: Making the Turret Cont.
Next, grab 2 1X1 tiles and put one on each 1X1 piece.
Step 14: Making the Turret Cont.
Then, grab 1 1X2 jumper plate and put it opposite of the 1X2 piece.
Step 15: Making the Turret Cont.
Finally, grab 1 telescope piece and put it on the jumper plates single stud.
Step 16: Assembling the Tank
Grab all the parts that you made and put them together, it should be very simple :).
Step 17: Congrats!! Your Done :D :P
Hooray, you hopefully did it!!!!
Now that your tank is assembled, it will be rolling out, KA-BOOOOOM!!!!!!!!!!
